Towing with a Ball and Drawbar
   / Towing with a Ball and Drawbar
"Another possibility is the EZ mover advertized here. Bolts to your drawbar and uses a top link. Put a receiver hitch in it."
Where can I find the EZ mover advertisement or the drawbar lock? I think I will get one of them.
Thanks.
   / Towing with a Ball and Drawbar #12
</font><font color="blue" class="small">( Where can I find the EZ mover advertisement or the drawbar lock? I think I will get one of them. )</font>
John, if you look at the second thread in this fourm (attachments) you'll wee the EZ mover ad. Just click on that link as you do for any other thread. Happy New Year, John
   / Towing with a Ball and Drawbar #13
Question? Looking at the attachment that jinman posted of the 8N with the sway bars attached to the top link, will that lift work that way? It appears to me that if you would engage the lift it would bend the 2 sway bars? Just curious.
sherpa
   / Towing with a Ball and Drawbar #14
</font><font color="blue" class="small">( Question? Looking at the attachment that jinman posted of the 8N with the sway bars attached to the top link, will that lift work that way? It appears to me that if you would engage the lift it would bend the 2 sway bars? Just curious.
sherpa )</font>
You are exactly right, Sherpa. The reason for the stays is to lock the arms into position so they will not move. Many of us have towed an old trailer with a split tongue which fits over & under the drawbar. That's how trailers were made before trailer balls became popular. With those trailers, you didn't have to worry about the drawbar rotating, but if you started too quickly or got a load too far back on the trailer, the tongue would just raise the lift arms since the lift cylinder is single-acting. To prevent this unstable situation, the lift-arm stays were invented.
If you look at my photo again, you will see that the stays are slightly bent. That happens when someone forgets they are attached and raises the 3PH. /forums/images/graemlins/blush.gif You have to use your "noodles" when the stays are attached. On the other hand, they hold the lift arms so they won't flop around. They are also two-piece assemblies, making them adjustable in length. This allows the drawbar to be set at different heights for different trailer applications. I suspect the old Ford tractors have pulled lots of drawbar towed implements with varied height requirements.
If you forget and raise the lift, most likely the pressure relief valve will open and save the lift arms from looking like doglegs. That was the case in the old Fords where the 3PH maximum lift was 2000#. I wouldn't recommend the stays on a newer tractor unless they were "beefed up" quite a bit. /forums/images/graemlins/smile.gif
   / Towing with a Ball and Drawbar #15
Thanks jinman. I just wanted to make sure. I have an 8N and have experienced some of the things you talked about.
I like that setup except for the part where you would bend the bars with the lift.
Sherpa
   / Towing with a Ball and Drawbar #16
I think its a lot easier, cheaper, and safer to just use the non-lifting, fixed draw-bar. I don't know enough about the 8n, but I would assume it can be equipped with a fixed drawbar.
Yes, you give up the ability to lift the trailer tongue with the 3-point, but its not like most people are moving a hundred trailers around every day.
   / Towing with a Ball and Drawbar #17
Jinman, being master of the obvious and having been raised on an 8N, one does never have the PTO engaged (also operates the lift) when one has the drawbar with stays in place. The stays will keep it from dropping. BobG in VA
   / Towing with a Ball and Drawbar #18
I have attached a picture of my setup which is a stabilizer, weight bracket, and boom pole mount. That is a chunk of solid lead bolted to the bottom.
   / Towing with a Ball and Drawbar #19
Keeny, I'm thinking the same thing. I'm still very new at all this, but why wouldn't one just mount the ball on the fixed draw bar. What am I missing? (Haven't tried it yet). Will a sharp turn jack the trailer against the rear tractor wheels or something? Go ahead, call me dumb, I can take it. Just don't let my me destroy my nice new tractor or the nice new trailer.
I see how it could be convenient to lift the trailer with the 3pt though.
   / Towing with a Ball and Drawbar #20
There might be a problem of tire clearance and turns on some tractor and trailer combos (not mine). Depends on tongue length etc. I guess. There are also drawbar extensions and adjustable drawbarsfor extra length. On the rare occasion my truck can't do the job, I just put the ball on the swinging drawbar and pin it.
2017 MACK CHU613 PINNACLE DAY CAB (A53843)
2017 MACK CHU613...
200387 (A51247)
200387 (A51247)
2008 JCB 520-40 TELESCOPIC FORKLIFT (A51406)
2008 JCB 520-40...
2001 HAULMARK ELITE II 8' X 24' CARGO TRAILER (A51247)
2001 HAULMARK...
2017 KENWORTH T880 (A53843)
2017 KENWORTH T880...
2016 Nissan Altima 2.5 Sedan (A51694)
2016 Nissan Altima...
