Tractor no. 15 !! It will be Cat yellow and have TRACKS !
   / Tractor no. 15 !! It will be Cat yellow and have TRACKS !
aaasulky.jpgThis morning I dug out the little trailers , now you can see a little better the round fender sulky project. I want to mount this old style spring seat on it next.
I got the lift linkage fabricated yesterday for the jd 110 snowblower. It works great ! Also I robbed a couple hubcaps off my other jd to see how the 110 would look ? I actually like them on it !:thumbsup:aaalinkage2.jpg
   / Tractor no. 15 !! It will be Cat yellow and have TRACKS ! #303
Yep, gooder-un. :thumbsup:
Today I decided to take my little air compressor that has sat around for several years and scuff it up with sandpaper along with my 30 year old portable air tank and slap some yellow paint on them. Then I decided to install larger tires on the rear and next I will install front tires on it with a wagon type pull handle . Also I want to build a cradle bracket to carry the portable air tank cross wise on the rear for easy pick up use.:cool2:air tanks 002.jpg
Today I fabricated the front axle and attached the front steering wheels. I need to build the brackets for the handle yet and build the rack for the portable air tank on the back . These were the old junker tires from my articulating Bolens . I had to torch off the two rear wheels so I was glad i was able to make them work on something after all. Four more tires used up , yippee !:cool2::dance1::cool2::dance1::cool2::dance1:aaacompressor1.jpg
   / Tractor no. 15 !! It will be Cat yellow and have TRACKS ! #306
Today I fabricated the front axle and attached the front steering wheels. I need to build the brackets for the handle yet and build the rack for the portable air tank on the back . These were the old junker tires from my articulating Bolens . I had to torch off the two rear wheels so I was glad i was able to make them work on something after all. Four more tires used up , yippee !:cool2::dance1::cool2::dance1::cool2::dance1:<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=421838"/>
Looking good
   / Tractor no. 15 !! It will be Cat yellow and have TRACKS ! #307
You could use four more for the portable tank, then you could pull them like little tanker train cars. :laughing:
Ha, Ha , that would be pretty cool !!
We returned from a great spring Vacation. Today I fired up the grader for the first time this year and fired up Deb's rear engine JD 68 . While raking leaves today I found two spots of ice 4 inches thick . Tomorrow I will fire up three more tractors. I did a little welding in the shop today. :dance1:aaaspringstart3.jpg
I have now fired up 13 of my 16 tractors . Tomorrow I will try starting up the last 3 .:confused2::confused2:aaabolens1.jpg
   / Tractor no. 15 !! It will be Cat yellow and have TRACKS ! #310
I have now fired up 13 of my 16 tractors . Tomorrow I will try starting up the last 3 .:confused2::confused2:<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=423263"/>
Love the one with loader will you build any equipment for the loader
2016 Dodge Journey SUV (A55758)
2016 Dodge Journey...
2007 Amkus Rescue System (A53421)
2007 Amkus Rescue...
UNUSED LANDHONOR RGB-11-72W - 72" ROCK GRAPPLE BKT (A54757)
UNUSED LANDHONOR...
JOHN DEERE 560M LOT NUMBER 28 (A53084)
JOHN DEERE 560M...
BUNDLE OF DOUBLE AXLE FENDER INSERTS (A54756)
BUNDLE OF DOUBLE...
