Tractor opinion?
   / Tractor opinion? #11
VTtractorguy:
Go for it :D! You will probably find that the 2210 more than meets your needs. Many times it is the skill of the operator not the tractor HP that makes the real difference in getting a task done. I do the same things now with my
29/23+ HP tractor (with FEL) as I did with my 13/11+ HP tractor (w/o FEL) for 20 years on my property. I just do things a little more quickly and efficiently and I can approach my tasks differently. You might have to rotary cut a little slower and/or overlap cut a little, but a lot depends on what you are cutting. I would jump on this opportunity :cool:. Jay
   / Tractor opinion? #12
Did you thorougly exhaust your search for the larger models? There might be one near your price point. The 2210 sounds liek a good deal, and you might find that you really did not need the additional size after all. I went from a 4100 to a 4310, and I just cannot get over the comfort, the reduced time to handle my jobs and the additional power. however, I got a great deal in trade for my 4100!
   / Tractor opinion? #13
Always make sure that there are no outstanding UCC liens on the tractor filed at the state or county level. If it was financed by JD (or others) chances are there is a lien filed on it which means that you may not legally own it even if you pay for it. To avoid a nasty lesson, check at the state, county courthouse, dealer or an attorney for some insight.
   / Tractor opinion? #14
35 hours? I've seen new tractors with almost that much from parking lot driving!! hasn't even seen it's dealers 1st 50hr service yet! Still in diapers..
Soundguy
   / Tractor opinion? #15
jbrumberg said:
VTtractorguy:
Yes as long as the hours don't rise too significantly then it should be a good bargaining tool.
   / Tractor opinion? #16
BUY IT, I loved my old 2210. :cool:
   / Tractor opinion? #17
With just 10 acres...you are tractored enough...:D
2007 Hyster S30FT 3,000lb. LP Forklift (A60460)
2007 Hyster S30FT...
2009 Peterbilt 335 Cab and Chassis Truck (A55852)
2009 Peterbilt 335...
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
2021 JOHN DEERE 6145R TRACTOR (A59823)
2021 JOHN DEERE...
2008 MACK CHU613 TRI AXLE 16FT DUMP TRUCK (A58018)
2008 MACK CHU613...
Toro Sand Pro (A56859)
