!!! Tractor Post Hole Digger with the Best Value & Complete Video Tutorial !!!
   / !!! Tractor Post Hole Digger with the Best Value & Complete Video Tutorial !!! #1
EverythingAttachments
Elite Member
Newton NC
Which One do you want to know about?
In this video, Ted shows you why The Everything Attachments 3pt Post Hole Diggers are the best value on the market. Ted narrates as Peanut digs some holes in the how-to demonstration with a couple of different tractors.
He also talks about the different PHDs and augers that we offer.
Rather than offering one basic phd for the various tractor sizes that are available today, we make multiple sizes to ensure the best fit for your particular tractor and application.
All of our PHDs are made in house, come with a Class 4 driveline(PTO shaft), and are designed to use a standard 48" long auger. The quality augers that we offer feature replaceable corkscrew tips and bolt-on cutting teeth.
**Everything Attachments Compact PHD is rated for up to a 12" diameter auger, and is designed to fit perfectly on Subcompact and Class 1 Compact Tractors with a Category 1 3pt Hitch.
FREE GROUND SHIPPING TO YOUR HOME within 1,000 miles of Newton, NC
**Everything Attachments 6900 PHD is rated for up to a 12" diameter auger, and is designed for Class 2 and up Tractors with a Category 1 3pt Hitch.
**Everything Attachments 6900 Heavy Duty PHD is rated for up to an 18" diameter auger, and is designed for Class 2 and up Tractors with a Category 1 3pt Hitch.
**Everything Attachments 7500 Heavy Duty PHD is rated for up to an 18" diameter auger, and is designed for Tractors with a Category 2 3pt Hitch.
FREE SHIPPING TO A COMMERCIAL BUSINESS OR SUPPORTING FREIGHT TERMINAL within 1,000 miles of Newton, NC
**Everything Attachments 7500 Heavy Duty PHD with HD Gearbox is rated for up to a 24" full flighted auger or 30" tree auger, and is designed for Tractors with a Category 2 3pt Hitch.
**If you need an additional auger, check out the Everything Attachments HD Auger Bits.
Give us a call, an email or ask us a question on here if you need help sizing a Post Hole Digger for your tractor or to locate a freight terminal in your area for larger items!! Shipping is generally very reasonable if you're outside of the free zone.
Travis
And now the video, shot on 10/8/2014:
   / !!! Tractor Post Hole Digger with the Best Value & Complete Video Tutorial !!! #2
Re: !!! Tractor Post Hole Digger with the Best Value & Complete Video Tutorial !!!
I know what a Cat2 three point is, but what is a category 2 tractor and why is this confusing nomenclature introduced rather than focusing on PTO power and three point category?
Moreover, your post hole diggers are not quick hitch compatible. Do you know if a QH compatible post hole digger exists?
Thanks.
Thanks.
Ted touches on the differences in tractor classes in the video.
The little Bobcat in the video is a Class 1 compact.
The class, referring more to the frame size, goes beyond PTO power and 3point category.
I do not know of a QH compatible PHD because the boom connects directly to the toplink housing on the tractor.
Travis
As a reference, here are a couple of charts from the Massey Ferguson website showing the frame classification of their 1500 and 1600 series tractors:
   / !!! Tractor Post Hole Digger with the Best Value & Complete Video Tutorial !!! #5
Just out of curiosity do you have any hydraulic down pressure kits compatible with the old Leinbach PHDs? I bought one used off a friend & started looking for the down pressure kit just after Leinbach went under.
Something close would be fine as I can weld & retrofit a bit if the price is right.
The only down pressure kits that we offer are by Danuser. I do not know if they'd work with Leinbach, but I don't think the price is right anyway!
Danuser Downpressure Kit
Travis
   / !!! Tractor Post Hole Digger with the Best Value & Complete Video Tutorial !!! #7
Travis
Keep strapping heavy things to the end of the PHD then it is!
Here's a Post Hole Digger review that we received over the weekend from Jeff in VA. He purchased our Everything Attachments 6900HD PHD with a 9" auger.
"I have to be honest here folks. I was a bit unsure about this PHD because it was about $500-$600 cheaper than other similar PHDs I was looking at.
Long story short: This thing is awesome! I've done 20 of 80 needed holes so far and I couldn't happier. Plus it was free shipping. These guys are awesome. Thanks EA!"
Jeff
Landhonor Skidsteer Portable Screener (A59814)
Landhonor...
WIGGINS 5K FORKLIFT (A58214)
WIGGINS 5K...
2002 Chevrolet C8500 Flatbed - CAT 3126 Diesel - Eaton Fuller 8 plus 2 Transmission (A56438)
2002 Chevrolet...
2016 FORD FUSION SS (A60430)
2016 FORD FUSION...
SKID STEER ATTACHMENT SIFT BUCKET (A58214)
SKID STEER...
Deere 333E (A60462)
Deere 333E (A60462)
