tractor use assumptions
   / tractor use assumptions #21
I don't have a backhoe, but the way I look at things you just need to use it enough to off set the depreciation. Once you feel you no longer need it you can always sell it.
Other things have already been mentioned, quick attach forks, grapple bucket, box blade, rough cut mower. (I would purchase a zero turn for the yard, just much faster if you have to mow around anything) snow blower if you have a driveway of any size as most do with that kind of acreage.
You will find a use for all of it, if you have it.
   / tractor use assumptions #22
I wouldn't see much use for a backhoe or boom pole but add forks and rotary cutter. Depending on what you plan to do with the land and its current shape will depend on a couple of times. You could always use a landscape rake and other leveling implements when you are starting fresh. Sounds like you will get lots of hours of use.
   / tractor use assumptions #23
Love my ho.
Yes I can't really justify owning but I do find use for it on a daily bases. If you have the means I highly recommend one.
rotary cutter = brush hog or equivalent?
   / tractor use assumptions #26
3 pages already - I'm late to the party! Nothing lights up the thread post count like asking what tractor you should buy! :laughing:
Based on what you have said, I think you are thinking a bit too small on your tractor. Sounds like a lot of mowing and snow plowing in your future. You will need to decide if you need a cab or not. Certainly something that will be much nicer in the winter, especially as you get older. If you do, and given the size of the property you are describing, I think you are into the 40+ hp range. In Kubota's line, the L-series is the right frame size and hp for what you need. They have "stripper" versions that are cheaper and the Grand L series that can come with a cab or not. Cabs are not easy or cheap to add later, but it can be done - aftermarket usually. This would put you into the L4240 or larger class, which gives you the largest size loader in the range (never can have too much there). I wouldn't want a B-series for that as I think it will be too small in the long run. As far as other brands, you would need to see what they have that is roughly equivalent of that (I just happen to only really know the Kubotas well enough). Whatever brand has a good nearby dealer would be a major driving factor, IMHO.
I only have 10 acres, but it is very hilly and wooded. I seriously wish I had gotten a larger hp tractor as mine is the smallest in the range (L3130), but I bought used and you always make compromises when doing that. Plus I was new to tractors too, and didn't know enough.
Good luck with your endeavors.
   / tractor use assumptions #27
I know this is a resurrection, but seeing as how we are 'neighbors'....
I went through a similar decision process, though I have a house & 10 acres, we have been buying with an eye towards a chunk of land.
I started with an old Case VAC (cheap, sold it for a bit more than I paid for it after using it a few years).
So, a few thoughts or questions that will help direct you:
Tractor hp comes in 3 flavors: drawbar, pto, engine. Advertised and Nebraska Tractor Test levels (and associated world wide testing organizations).
Tractor size is something different. There are compacts, sub-compacts, and utility sizes (at least in what you want). Each brand has its own language/marketing terms for what is more often than not the same thing.
Personally, I would lean towards Utility size. Or compact at the smallest. You have lots of projects you will want to do.
When deciding on your tractor, price the implements (and keep in mind that there are similar standards to them: light, heavy, commercial). The ground is hard, as are rocks and roots. You never regret a good unit, but you do one that is too light. Box scrapers are one of those implements. Implements around here are relatively plentiful on Craigslist up to about 6' wide. Then the pickings get real slim.
Excavators are cheaper (relative to owning a backhoe that rarely gets used) to rent and more mobile than a backhoe. Especially when you build you will likely pay someone to dig the basement (if you do a walkout you can likely do it with your tractor). Same with the utilities. Price out you doing it and someone else digging and laying it out. It might be cheaper to do power overhead (and keep it out of the way when you decide to do something different on your property, digging wise). Phone they can just vibrate in.
Grapple buckets and quicktach (Bobcat style loader) forks are real labor and back savers. If you find an older tractor with loader (or, one that a loader can be put on) you can get adapter links for the bucket and convert it.
The ground here is brutally hard except for the 1 day to two months of spring . 3 point post hole diggers are not what they are made out to be (they work if you have good bits and plan well). Get a 3rd circuit (remote) for the bucket area (it can be used for other things on the rear implements) and buy a low flow used hydraulic post hole digger (by the way, if you do get a backhoe, you can mount one of these on the side of the bucket to reach where ever you want). And Bobcat of the Rockies (Parker is closest) rent the quicktach units out (you will need either enough hydraulic flow on the tractor pump or an add on system for the PTO). Just call ahead and request the low flow unit on the full sized plate. That's if you don't buy one.
Some folks buy a used skid steer or rent one as needed for projects that are more intense.
Snow removal is very spotty, as we don't generally get that much snow, and often it is lighter. Blowing & drifting is a bigger issue, as is the distance from where you are to anywhere else. Hwy 86 has a number of road closure bars permanently in place for those events. Good planning for your driveway will make access much easier and snow maintenance faster. You will want a modest downhill on one side to push it off, as well having it exposed so that it blows off (versus drifting). That makes it easier to have turn around room adjacent to the driveway anyhow. You will want (or wish) you had a cab on the tractor. It keeps you warm in the winter and out of the dust and blowing weeds in the summer.
Do you really plan to mow more than what is around the house and along the driveway? Then you want a riding mower. I had a 36" unit, replaced it with a 42". It's too wide. Let the deer and antelope eat the grass (or a couple of head of cattle -- ag write off). Except for areas you water, you will only be mowing once or twice a normal year.
Get teeth for the bucket. And a 'swing out' rear blade (if you end up buying new, or can wait to shop and find the right one). It will let you stay off of the fence or allow you to ditch clean (edge of a crowned drive).
2 wheel drive tractors work, but only if you realize that you must chain up for winter or wet spring work. And ag tires (r1): they work (and are usually on older tractors).
Since you work on your Porsche, you can work on most tractor issues. They involve rust and large parts. In any case, a shop of decent size (they are never large enough) is something you will want. Build it before the house. Maybe even with the ability to have an 'office' in it (that you could stay in during weekends while the house is being built or other pre-build activities are ongoing). That way you have a place to put your equipment and to be in if/when a hail storm comes through. You want a metal roof for it (wind and hail).
PM me if you would like to stop by some time.
   / tractor use assumptions #28
We have a 200 acre bushlot on a lake. We, like you decided to build a house and retire there. We bought a compact tractor w/loader. I wrestled with a backhoe, because of price. After paying a guy $5,000 for the driveway. ($1,500 for the digging part) and $1,500 for the excavation of the house, we decided to get the hoe. We have probably saved another $10,000 on all the projects that came up since we got it.
The point is, it doesn't matter. Whatever attachments you do get, you will find a use for or sell off and replace with another you need. Last Friday we took ownership of a new larger engined compact (25 hp out 35 hp in) to better operate the snowblower and got most of what I paid back on the trade. (prices went up almost as much as depreciation).
Last point, you will probably get a better price on implements if you buy a package deal. Good luck and welcome to the addiction!
2009 JACK COUNTY KILL TRAILER (A58214)
2009 JACK COUNTY...
Adams Tender / Magnolia Trailer (A56436)
Adams Tender /...
2020 DRAGON ESP...
2018 MACK GU813 DUMP TRUCK (A59823)
2018 MACK GU813...
Dodge Charger (A56859)
1605 (A57192)
1605 (A57192)
