Tractor use percentages
   / Tractor use percentages #11
One year, 160 hours on my BX 23
1% Chipping (if you have a PTO chipper) Just got it?
10% Moving dirt/gravel
20% Back Hoe work
5% Moving stuff with FEL(mulch, old dog houses, refridgerators, etc...)
5% Finish grading
20% Snow work
1% Idling while your doing something else and start up and cool down).
30% Finish Mowing
00% Bush Hogging
00% Digging with the FEL
00% Mixing concrete (if you have a PTO mixer)
00% Plowing/tilling
00% Logging
00% Ag (hay, planting)
00% Spraying
5% Driveway maintainence
3%Anything else
100% happy, Richard
   / Tractor use percentages #12
Pretty cool survey....
10% Back Hoe work
30% Moving stuff with FEL(mulch, old dog houses, refridgerators, etc...)
5% Finish grading
20% Snow work
05% Idling while your doing something else and start up and cool down).
00% Finish Mowing
10% Bush Hogging
10% Plowing/tilling
00% Logging
00% Spraying
OK, Johnk. What do you do with the other 5%.
I think the survey is showing an interesting mix, perhaps more of a mix than I expected. It seemed from posts in general that owners tended to use their tractors mostly for finish mowing and Bush Hoging. Turns out this is quite wrong, at least with the responses so far.
I've also noticed that for people with back hoes use them a lot.
Hopefully more will post so we can get a more meaningful analysis.
Cliff
   / Tractor use percentages #14
Hello,
Well this year is very different from the last two years because I bought a backhoe and it's been so dry that the lawn dosen't need mowing too often! So I'll only write down for this year:
0% Chipping (if you have a PTO chipper)
25% Back Hoe work
05% Moving stuff with FEL(mulch, old dog houses, refridgerators, etc...)
01% Finish grading
20% Snow work
30% Finish Mowing
00% Bush Hogging
01% Digging with the FEL
02% Plowing/tilling
01% Logging
00% Spraying
00% Driveway maintainence
Anything else
Hypernix
   / Tractor use percentages #15
As of right now:
00% Chipping (this would change if I had a PTO chipper)
30% Moving dirt/gravel
20% Back Hoe work
15% Moving stuff with FEL(mulch, old dog houses, refridgerators, etc...) Logs, Rocks
05% Finish grading
10% Snow work (do most of this with the F-250)
01% Idling while your doing something else and start up and cool down).
05% Finish Mowing
00% Bush Hogging (will be more when I get the new bush hog)
05% Digging with the FEL
00% Plowing/tilling
05% Logging
00% Spraying
00% Driveway maintenance (soon to be more, going to put in a new driveway)
04% helping neighbors with stuff.
But I am always finding new uses for my tractor /forums/images/graemlins/smile.gif
Gary
   / Tractor use percentages #16
900 hrs in 18 months
50% chipping
35% skidding logs
15%decking logs
The logging part is fun the chipping is hard work. /forums/images/graemlins/crazy.gif
   / Tractor use percentages #17
10% Chipping (if you have a PTO chipper)
20% Moving dirt/gravel
15% Back Hoe work
02% Moving stuff with FEL(mulch, old dog houses, refridgerators, etc...)
20% Finish grading
00% Snow work
00% Finish Mowing
05% Bush Hogging
00% Plowing/tilling
00% Logging
15% Spraying
12% Driveway maintainence
Anything else
I had to juggle the numbers 5 times because my first time through I had 165%. Lots of guessing. Fun, too. 180 hours in 4-1/2 months.
   / Tractor use percentages #18
Brush hogging 70%
Moving brush 10%
Driveway maintenance 5%
Tilling or disking 5%
Other stuff with the loader 9%
Stupid Tractor Tricks 1%
   / Tractor use percentages #19
With the new Deere, 50 hrs:
Drive way maintenance 10%
Bush Hogging 20%
Moving dirt & gravel 30%
Harrowing, pasture planting 10% (This will increase drastically in late fall)
Clean-up logging mess 29%
Idling 1%
Old Kubota:
Driveway maintenance 90%
Bush hogging 9%
Idling 1%
   / Tractor use percentages #20
Century 2535 compact tractor
15% Post Hole Digging
40% Bush Hogging
30% Pulling Trailer with tools and generator
10% Pulling log with fence to smooth fields
5% Disking Fields
Ford 555E
30% Backhoe
60% Loading and hauling dirt
10% Smoothing Roads and Dirt
Case 1550 dozer
50% Clearing brush and trees
40% Digging dirt
10% Grading roads and pads
Eddie
Sterling AT (A56438)
2012 TROXELL 130 BBL STEEL (A58214)
2012 TROXELL 130...
UNKNOWN  SPOOL TRAILER (A58216)
UNKNOWN SPOOL...
FUEL CELL TOOLBOX COMBO (A58214)
FUEL CELL TOOLBOX...
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
