Tractor won’t start!!
   / Tractor won’t start!! #1
Bonbon
LS MT122
Our tractor will click but won’t start. We replaced fuses, checked safety switches and can’t find anything except this weird wire that seems to go nowhere. What is this and should it be attached to something?
   / Tractor won’t start!! #2
Check all you cables to see if ends are clean
willy
   / Tractor won’t start!! #3
That just looks like a clamp for all the wires and hoses to me.
   / Tractor won’t start!! #4
When u hear a click, then nothing happens, and then no lites on the dash, 9 X out of 10 it’s the battery cables not making a good connection..
Get a battery terminal/cable cleaner.. they’re like $2.00 at Harbor Freight..& do a fantastic job at cleaning the posts and cable ends..
If u SEE GREEN on the cable ends, chances are good that they’re corroded up inside the covering..& probably need replacing.
   / Tractor won’t start!! #5
Are you hearing the click from the starter motor solenoid when you turn the key to on position? Or is it coming from somewhere else?
Kuhn FC400RG (A60462)
KUBOTA X1140 CREW RTV (A52706)
KUBOTA X1140 CREW...
Wacker Neuson RD12 (A57148)
Wacker Neuson RD12...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A58017)
2018 INTERNATIONAL...
204549 (A52707)
204549 (A52707)
2021 Harley-Davidson FLHP Road King Motorcycle (A59231)
2021...
