tractor wont start
   / tractor wont start
i cleaned the ground at frame
   / tractor wont start #52
" But you have to isolate the cause of the heated ground wire before messing with the rest of it."
Often heated cables or wires suggest internal corrosion but for sure it can't carry the amperage it should to drive the starter at correct speed.
For how little it costs, install a new ground cable, and be sure that there is good bare metal where the ground cable is attached.
Crappy corroded cables (wire) will carry voltage but not amperage and a starter wants lots of amps!
Just might be the cause.
   / tractor wont start #53
YES!!!!!
Also if engine is not solidly bolted to frame (as it should be) is there a ground jumper from frame to engine block....
IF it were me, I would run new ground cable from battery to any bolt holding starter to bell housing or engine block...
Dale
   / tractor wont start #54
YES!!!!!
Dale
marine grease prevents this problem from occurring in the first place, it keeps the moisture out, and because of it's formulation, the grease never dries out, and is very resistant to even rain..
   / tractor wont start #55
My preference is either dielectric grease, or NO-OX-ID compound...
Dale
2022 New Holland Powerstar 90 Tractor with Loader (A51573)
2022 New Holland...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A51692)
2013 Ford F-150...
2013 International DuraStar 4300 Box Truck, VIN # 3HAMMAAL1DL085200 (A51572)
2013 International...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A52748)
Neckover GL24-2-7K...
2019 Nissan Sentra Passenger Car (A51694)
2019 Nissan Sentra...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
