Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #5,701
Cleaned up a bunch of dead elm that I was starting to get tired o looking at this morning
   / Tractors and wood! Show your pics #5,703
This is a firewood chunker...
The farm co-op had one of these... my grandmother used the wood side of her stove most of the year and everything was "Chunked"
   / Tractors and wood! Show your pics #5,704
And you climbed one to take the picture?
I'm in MI too, and I guess it's snowing. On Vaca in Kentucky...
Look closely at the ground coming into the loader valve area of the tractor. Took the picture from a tree stand right above a busy deer run :)
Not sure where the rain / snow line is but heard there could be 5" up your way so KY sounds like a good choice. Rain & high wind advisory here now (100 miles south of 55).
   / Tractors and wood! Show your pics #5,706
No shortage of retired around the farm when I was a kid that would go in and scavenge the forests for branches after trees came out... some actually paid a nominal amount to the landowner which only covered branches or small windfall.
One guy had a VW Bug with a trailer... he would load it with a massive amount of branches when the forest was no muddy... when it rained he had a large carport with a jig to cut the branches to length.
Put 20 or 30 branches on the jib and then slice through in 14" slots.... jig was 8' or so... when done... with a couple of cuts he had hundreds of branches cut to length...
He used an electric chain saw under the carport and a bow saw and giant loppers in the woods.
   / Tractors and wood! Show your pics #5,707
66 and sunny. Diggin it and don't wanna go home tomorrow.
   / Tractors and wood! Show your pics #5,708
Made one test run today, I went from 75' of old cable to 133' of new cable, did seem like I lost a little pulling power on the winch, dont know if it's because I might of got my greasy fingers on the spool pressure plate or because there's more cable on the spool, have to make a few more test trips.
   / Tractors and wood! Show your pics #5,709
I'm still welding there, 31 years and counting, I can assure anyone there are some great welders at BIW, second to none especially the tig pipe welders, I tried that and didn't pass the die test so I stayed in the machine welding of bars and shell plates. Some of these guys I work with weld .045 solid wire vertical up and it comes out like perfectly stacked dimes and lot of it, every day, all day long, me I go to Dual Shield flux core for up welding. Every inch of weld is spatter free and a lot of welding is done with mirrors<<<that will separate the men from boys really quick.
I retired on May 27th 2016.
I did my share of mirror welding there that is for sure. That does separate men from the boys, and I did my share when I worked on 5 skids, but when they ended that, and I moved to the aluminum shop and PVLS, there was very little mirror welding just because the nature of what it was.
I am like you, I prefer flux-core on the vertical up welding, but PVLS meant Pulse Welding only. I am not saying it was better or worse, it just was not allowed by Navy rules (as you know I am sure). I also spray-arced though, sometimes on PVLS stuff when it was not critical and allowed, which few welders do there. My best day ever was (5) rolls of wire in a single day on a 155 pass PVLS fillet weld! That was pretty good, but I don't blame you for not wanting to Tig weld. I knew a lot of old welders that could Tig Weld if they wished, but chose not too.
The poor reputation of BIW welders though does not come about because of quality, but because of work ethic. They used to tell me I was the "reason they did not get overtime", and I told them, "they were the reason we did not get ships." Few employers will hire BIW workers...not because they are not skilled, but just because they are not hard workers. Not every worker of course, but the few ruin it for the rest.
I am sure we know A LOT of the same people though, especially when it comes to Welder Leadmen and such.
   / Tractors and wood! Show your pics #5,710
Broken Track - What is PVLS?
   / Tractors and wood! Show your pics #5,711
Adding layers of rope, really cuts down on the pulling power...
SR
   / Tractors and wood! Show your pics #5,712
That is nice wood. All straight and barkless. My favorite firewood since it is so clean.
I don’t mind the crotches. A little more fussing with but lots of BTUs locked up in there.
   / Tractors and wood! Show your pics #5,713
SR
That's pretty simple physics. It's the same thing as using a pry bar or using a pipe over a ratchet handle except the leverage isn't in your favor.
   / Tractors and wood! Show your pics #5,714
I don't mind the forked pieces that only had two pieces growing out of it. I usually cut those most of the way through with the saw while I'm cutting wood. The 3 or more head pieces unusual get tossed.
   / Tractors and wood! Show your pics #5,715
With the supply of dead ash nearly exhausted the dead elm is next in line. There's quite a few years worth out there. Even though the ash died after the elm the elm stays solid forever compared to the ash.
You're in for a rude welcome home ;)
   / Tractors and wood! Show your pics #5,719
This is the size I hate. Way to much time to work it up w/o being set up for small wood. But it burns. This is road side clean up after the power line crew can through and trimmed out the line.
gg
Those are the size I love - just put them in a cutting buck and cut many at a time - no splitting and put them in a cage and you are done. The quickest way to make firewood if they are straight and not too many branches to cut off during bucking.
   / Tractors and wood! Show your pics #5,720
I agree. I have a lot more trees than I need, so I cut the smaller ones to allow the best more room to grow. I am working out a way to put the cutting buck onto my ATV trailer, so that I can process it right in the woods; I have a LOT of trees scattered around on the ground, which were in the way when I was bringing spruce logs out this winter.
2005 Honda Accord LX Sedan (A59231)
2005 Honda Accord...
2013 Ford Edge Limited AWD SUV (A59231)
2013 Ford Edge...
2002 FORD F-350 XL SUPER DUTY FLATBED TRUCK (A60430)
2002 FORD F-350 XL...
MASSAGE CHAIR (A58214)
Le Roi 80-Gallon Air Compressor, 220 Volts (A59076)
Le Roi 80-Gallon...
JCB 507-42 TELESCOPIC FORKLIFT (A60429)
JCB 507-42...
