rocketfish
- Joined
- Jul 7, 2014
- Messages
- 112
- Location
- The corn fields of Indiana
- Tractor
- 2014 JD 2025R, 1986 JD 330
Very nice as always Gordon!
Probably a good source of protein too for those long days in the woods.Any feedback?
Visiting a friend up in Canada, I helped him cut up a tree. He had these cheese slices that he uses a lot. I have to admit they were nice and light and i could tap one in with the butt of the other to prevent pinch on the blade. They are Stihl plastic wedges and seemed to be built well. Any feedback?
I carry 3 of them, wedges or felling wedges, in my chaps pouch all the time. Two 5 inchers and an eight. They are indispensable in preventing a pinched blade and split saw logs when bucking logs under compression that you can't easily just roll over. There value is even greater as a directional felling aid.
gg
Right. Just never used the plastic ones. Sure made for faster cutting.
OK, I think I under stand your question now. Well besides plastic I have used pre bought wooden wedges and wedges made on the spot out of the face cut wood. While blocking firewood I have used a steel splitting wedge in the past. Can be hard on the saw chain :laughing:.
As far as doing the job best and holding up to the abuse the plastic ones are my choice by far. Their angle is right so they don't spit (sp) out on you when under pressure and some have a roughened surface to help hold even better. After you hit them with the saw a couple times you can remake them with a belt sander. The only things I don't like is that they seem to expensive for plastic even though they are worth the price and if it is very cold out, 0* F or so, you have to be careful starting them and hit them with a square blow because they might break off where the plastic is thin.
gg
9 bucks is a lot to spend on dulling a chain.
I usually mash the ends of my plastic wedges into the back of the back cut and booger them that way, but I've also notched more than a few with the nose of the bar. My primary use of wedges is directional falling against back leans, so it's not always fun stuff.
I'm waiting for the price on the 36" Wilton 6# maul to come down. That looks and feels like the perfect wedge slammer. Locally they want $124 for them, which is insane. Online they're around $90. If it got down to $60 I'd probably move on it.
And here I thought you were being facetiousRight. Just never used the plastic ones. Sure made for faster cutting.
Looks like Wilton dropped the ball with those unbreakable sledge/mauls. The heads come loose after a few months and their customer service says "you used it up. time to buy another one." I don't have to worry about keeping tabs on that accessory anymore.
Wilton used to be a class act and made outstanding wares. Sad to see them wind up like this.
