Billrog
Veteran Member
- Joined
- Dec 9, 2014
- Messages
- 2,054
- Location
- Armstrong, British Columbia
- Tractor
- Kioti 2610, 580 SuperM Case Backhoe
Very Nice !!
That's cool. I really need to get a 80-100 amp service in my barn i want to he able to do more serious fab work.I made my own cross wedge. It only has the power to 4-way 8-10". TSC sells a 4-way that would work.
Keep in mind, those "light duty" 4-ways are for soft wood only. I've heard of several complaints of guys bending them up pretty bad, trying to split hardwood, and/or tougher crotches...
SR
robpm-
What is the larger black plastic bin with the lid in the last photo?
Do you use that with your forks for hauling split wood?
Where can I find one of these?
This is a good example of why I think the bucket/forks are way to far out front of the front axle on modern 4x4 tractors, it does give more lift height, and with short wheel base, a tractor can turn in a small area, but for what I do I'd rather have the front axle closer to the bucket.
I don't have a quick disconnect bucket on my L3400, so I have to clamp on my forks on the bucket which makes it stick out farther from the front axle and for me I think that cuts down on lifting power and make my rear tires come off the ground easier.
https://www.youtube.com/watch?v=iDBSmZFOpKU
I received this one for free. I also found a guy that was giving away about 100 of them and I got a couple more. I was thinking about storing my wood in them because of their lids etc. The problem with the 100 is that they were pretty well beat upon and plus the guy did not want you to pick through them to find the best. In addition he was in a hurry to get rid of them. Then I thought if I ever move I have to find a place to get rid of them as well. So that is why I only ended up with a few of them.
You can buy them new at a place like Global Industrial and the pallet containers are made by Buckhorn and others.
Here is the Buckhorn unit
Bins, Totes & Containers | Containers-Folding | Plastic Folding Bulk Containers - GlobalIndustrial.com
Here is buckhorn's site and the black containers
Buckhorn Inc. | Heavy-Duty Bulk Boxes
I hope this helps.
Bins, Totes & Containers | Containers-Folding | Buckhorn Folding Bulk Shipping Container - BS3230342010000 - 32x30x34 1800 Lbs. Back | 238254 - GlobalIndustrial.com
I hope this helps.
I agree completely about the length of loaders these days. I couldn't get a 553, so rather than getting the H240 (which is easily 2' longer) I went down to the 512 instead. It theoretically cost me 600# of lift capacity and about a foot of height, but the total package is shorter yet than the 553 was. They're not a supported configuration from Deere, so there's only a handful of 5e 4wd's running the 512 loader, but I'm pretty sure it's because there might not be enough clearance at the suspension stops with the tires all the way in. Since my tires will be almost all the way out to stay just inside my 73" bucket, there's no issues.
I also wanted to comment about your short forks. That's a sweet little work around you did there.
