Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #14,011
And if I want, burn it in my new fire ring:
That's our camper in the ring.....
That fire ring is gorgeous! Did you have it made locally? Bummer that we have to drive so far to find "mountains" from central Michigan, huh. :p
   / Tractors and wood! Show your pics #14,012
It's hot now, but this was earlier this summer or spring...
Just hauling a bit. It isn't far away, so not too concerned about not hauling a ton. I split it out of the bucket usually so I don't have to lift.....
I got a saw haul:
I cut down this beast:
Haul it home:
Split it up:
This is how much of an IBC tote ONE piece got me:
I like the ring... other than the mountains part, resided in the Rockies for 7 years , no thanks
   / Tractors and wood! Show your pics #14,013
Yeah, mountains are a long drive....
Fire ring is from a buddy I went to HS with (been a while ago, these days). Mesick, MI
facebook.com/mymetalmedium/
   / Tractors and wood! Show your pics #14,014
Hard to see but my chainsaw bar had quite a bend in it and even the chain was bent a little, I got it straighten back out with a hammer to almost like new. I might even improved it now my saw has auto brake feature and now the bar has a nice gun barrel blue to the rails so it wont rust. Just in case it fails for some reason I'll fill out the 5 year Echo warranty card so I can get a new bar...
   / Tractors and wood! Show your pics #14,015
If you have a press this sort of setup works great on bars.
Thats a nice press the lack of paint tells me you built it, another one of them shop tools thats not needed all the time but at times it sure is needed. My younger son keeps talking about buying a HF press for his on going Jeep project.
   / Tractors and wood! Show your pics #14,016
Whats the two saw brands you have? Cool burn ring, even better when it's burning...:thumbsup:
   / Tractors and wood! Show your pics #14,017
Time to get the clamps out and start putting the bridge together.
Things were to good until......
   / Tractors and wood! Show your pics #14,018
I barely know. My F.I.L. was a dealer for the saw I use (the one on the tractor). An Efco, I think. I know nothing about it. Kungfu, I assume. Now that I have some time on it, I should run my dad's Stihl for comparison.... It isn't over-powered, for sure.
The one on the shelf is an ancient homelite. Though if I get my saw stuck, the grapple aids me, not a second saw.
Honestly, my dad usually drops blocked wood in my field. Before this, covid, year I have probably an hour on that saw. This year I cut up 10 or 15 cord through it. So, I'm pretty small-time.
We like the burn ring a lot, it's totally custom. I've been chopping up and burning busted up pallets. Keeps the nails contained... Though now we're camping again, so the ring just rusts/patinas.
   / Tractors and wood! Show your pics #14,019
All the bolts went in, the last one came to sudden stop half way so a little alignment needed.
The last part was putting drag cables on.
Things went pretty good til then.
Case 950 8 Row Air Planter (A55302)
Case 950 8 Row Air...
FRONTIER MG20F LOT NUMBER 80 (A53084)
FRONTIER MG20F LOT...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A55788)
2018 Ford F-150...
2007 Yamaha Rhino 660 (A55302)
2007 Yamaha Rhino...
1982 LeeBoy Motor Grader (A55302)
1982 LeeBoy Motor...
2022 Polaris Ranger Utility Cart (A53421)
2022 Polaris...
