Exactly two years ago I bought a new B3200 Hydro with R4 tires. I used it for snow removal and cutting my meadow. I have discovered my little B3200 just can't do what I need it to do. We have 40 acres, mostly wooded, that I decided to start cleaning up since it's littered with black jacks and huge limbs from ice storms. I also have areas that need leveling, or cut, and the oklahoma red dirt is impossible to work with. One section will be sandstone and 30 feet away will be sand. I just recently burnt a huge brush pile that was built with a dozer. There are some stumps left in the burn pile that I want to bury and I can't even lift them with my B3200. So...last friday I took my B3200 in for the first service and saw two tractors that I believe would do what I need.
So the two I am looking at are the L4400 and Mx4700. Both have HST and are comparable in size and weight. The price difference is $1500 with the Mx4700 being the more expensive tractor. At only 60 hours the trade in value on my B3200 is $12k which doesn't make me happy so bottom line I want to make the best decision I can for long term needs. I was told to buy the biggest tractor I could afford since I have a semi-large parcel of land. The only thing I think I will miss is the ability to maneuver around trees with the smaller B3200. Flip side of that is I can't tell you how many times I have almost buried my B3200 trying to get out of the woods and ended up crawling out with my FEL. I always wondered if it was the industrial tires but have recently learned it was the fact that the B3200 only weighs 1700 lbs.
Well I know my first post was long but I want to throw out as much info as possible because after lurking here for awhile I see that many of you have a wealth of knowledge that you don't mind sharing. I am about ready to pull the trigger but I have two decisions to make:
1) L4400 or MX4700
2) R1 or R4 tires
1) L4400 or MX4700
2) R1 or R4 tires
