Trailer brake controller on a Kubota BX
   / Trailer brake controller on a Kubota BX #12
It would take a stout switch also. There is a lot of current going to the brakes.
That would probably be good application for a relay.
Then you only need 1-2 lightweight wires going to the switch rather than 2 heavy ones.
Aaron Z
   / Trailer brake controller on a Kubota BX #13
Aaron Z
I was out mowing my back 3 acres and was thinking the same thing. Well done with lunch and back to the Iron Horse.
Chris
   / Trailer brake controller on a Kubota BX #14
I have a 35$ hoppy controller on my ford 5000 for when I pull my 16' tandem trailer for hay rides.
similar setup.. works great.
soundguy
   / Trailer brake controller on a Kubota BX #15
I put brakes on My L3400 in the fall of 2008. Coming down a steep mountain road with a trailer full of wood was not cool. On a couple of occasions, all it would take is a rock under one of the rear wheels for the trailer to push the tractor into a skid, or try to jacknife it.
   / Trailer brake controller on a Kubota BX #16
The last picture is a momentary push button that I use to activate the controller. I thought about using a switch activated by the brake pedals, but I didn't want it left on when I use the parking brake.
   / Trailer brake controller on a Kubota BX #17
have a disconnect on it to bypass when pbrake is on/.
soundguy
   / Trailer brake controller on a Kubota BX #18
soundguy
I thought about that, but knowing me, I'd forget that it was off until I was in trouble headed into a ravine!
   / Trailer brake controller on a Kubota BX #19
Use a normally closed relay that is triggered by the parking brake switch.
Aaron Z
   / Trailer brake controller on a Kubota BX #20
ok.. make one you can't forget about.. IE.. make the brake controller powered off the key switch.. unless you have the key switch off when you head into the ravine you will be ok.
soundguy
2024 Schulte 5026 Batwing Rotary Cutter (A56435)
2024 Schulte 5026...
1302 (A58374)
1302 (A58374)
Mini-Skid Steer Vibratory Roller (New/Unused) (A59225)
Mini-Skid Steer...
2007 GMC 2500HD (A56435)
2007 GMC 2500HD...
Water Line Hose (A59076)
Water Line Hose...
2008 Caterpillar G23G Scraper, S/N CAT0634GADBY00493, Cat Turbo Diesel, 12,763 Hours Indicated, (A59076)
2008 Caterpillar...
