Trailering Tractor with Forward Facing Exhaust. Issues?
   / Trailering Tractor with Forward Facing Exhaust. Issues? #11
Business opportunity... fancy exhaust corks :cool2:
   / Trailering Tractor with Forward Facing Exhaust. Issues? #12
Lots of controversy, threads. Placing a nerf football in the exhaust is easy. However if it is a problem would not the manufacturer say never to park the tractor in the wind? Reality is air in the exhaust needs to make its way through turbo, find a cylinder with both exhaust and intake valves open (BDC of exhaust stroke), back through turbo, ATAAC, air cleaner and out.
Might be easier on some equipment to put a bag over the air intake.
Bruce
   / Trailering Tractor with Forward Facing Exhaust. Issues? #13
I trailer my M9's once in a while, same as you, vertical stack. I just turned it sideways. Never an issue since 2006.
   / Trailering Tractor with Forward Facing Exhaust. Issues? #14
I trailer my M9's once in a while, same as you, vertical stack. I just turned it sideways. Never an issue since 2006. Nice tractor. I see Kubota has cheaped out on the bucket level indicator rod.
Don't want to turn it, stuff a rag in it.
   / Trailering Tractor with Forward Facing Exhaust. Issues? #15
I I see Kubota has cheaped out on the bucket level indicator rod.
What did it used to look like? I took the one off my tractor. The auto level on my backhoe was even worse. I sawzalled it off. I wouldn’t have hated it if I could override but it was a positive interlock.
   / Trailering Tractor with Forward Facing Exhaust. Issues? #16
Not sure on pipe size, but why not bolt a tractor exhaust flapper to the exhaust pipe? Would help keep wind, rain, and animals or other things out of the pipe
   / Trailering Tractor with Forward Facing Exhaust. Issues? #18
My JD 6415 was delivered with the exhaust covered. No idea if needed or not, but gave peace of mind.
   / Trailering Tractor with Forward Facing Exhaust. Issues? #19
Yes it's a thing.
Owners manual for my backhoe warns to cap the exhaust when trailering. Wouldn't surprise me if this isn't covered in your manual.
I made sure they taped mine up with duct tape when it was being transported to me but a rag might work for short distances.
I saw a company selling heat resistant bags for this somewhere but they were stupid expensive.
   / Trailering Tractor with Forward Facing Exhaust. Issues? #20
When I used to haul a lot of stuff we always covered a forward facing exhaust and a straight up exhaust if it didn't have a flapper on it or if the flapper was turned wrong for our direction of travel. The reason wasn't for the turbo though, it was to keep rain and debris out of the exhaust.
1998 CATERPILLAR 953C CRAWLER LOADER (A52707)
1998 CATERPILLAR...
2023 54ft Hooklift Dumpster 15 Cubic Yard (A55788)
2023 54ft Hooklift...
Cast Iron Mailbox (A55758)
Cast Iron Mailbox...
2000 GMC C7500 SINGLE AXLE VOCATIONAL TRUCK (A56129)
2000 GMC C7500...
1967 Ford F100 (A47477)
1967 Ford F100...
2019 KENWORTH T880 HYDROVAC (A53843)
2019 KENWORTH T880...
