transmission/Hydraulic fluid. Who's using what?
   / transmission/Hydraulic fluid. Who's using what? #31
Re: transmission/Hydraulic fluid. Who\'s using what?
B7510:
I'd not mix brands. At least that is what my dealer told me and I do trust him. A little low won't hurt anything. Just so long it shows on the stick or in the window.
   / transmission/Hydraulic fluid. Who's using what? #32
Kubota Super UDT. Heck, even the factory manuel recommends it.
   / transmission/Hydraulic fluid. Who's using what? #33
/forums/images/graemlins/confused.gif I wonder why the oil companies would bother to make Hydraulic Oil if Motor Oil will work just as well in hydraulics?? /forums/images/graemlins/confused.gif
These are a few of the qualities that make Amsoil Hydraulic Tractor Oil better than Motor Oil:
"" AMSOIL Synthetic Tractor Hydraulic/Transmission Oil is the modern lubricant for modern farm and industrial equipment. Engineered specifically to meet the tough applications of heavy-duty, hydraulic-powered operations, AMSOIL Hydraulic/Transmission Oil exceeds the performance requirements of virtually every piece of modern machinery. With its unique blend of synthetic base stocks and advanced additive package, AMSOIL Hydraulic/Transmission Oil provides exceptional lubrication to reduce wear, resist heat, protect against rust and extend fluid and equipment service life.
Remains Stable at Temperature Extremes
AMSOIL Hydraulic/Transmission Oil operates over a wide range of temperatures. AMSOIL Hydraulic/Transmission Oil has a low volatility and high viscosity index to maintain its lubricity at high operating temperatures, and it flows at temperatures as low as -40°F (-40°C) for improved equipment operation and wear protection.
Provides Controlled Seal Swell
AMSOIL Hydraulic/Transmission Oil contains seal swell agents to maintain sealing integrity. It provides a slight seal swell to maintain a secure, tight fit.
Inhibits Rust and Corrosion
AMSOIL Hydraulic/Transmission Oil contains special rust and corrosion inhibitors to protect tractor components against rust and corrosion.
Inhibits Foaming
AMSOIL Hydraulic/Transmission Oil inhibits foaming. Foaming reduces hydraulic oil pressure and diminishes the lubricating protection provided by the oil. AMSOIL Hydraulic/Transmission Oil continues to resist foaming even when the reservoir level is low. ""
Motor oil may work "OK", but why not use a product which is "engineered specifically" for use in a hydraulic system???
/forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Can I get an AMEN?
   / transmission/Hydraulic fluid. Who's using what? #35
Since you asked, AMEN.
   / transmission/Hydraulic fluid. Who's using what? #36
I agree use the right type of oil for the application. I use 20W50 motor oil in my Gravely Tranny, GL1 grease in my Troy built tranny, and Hy-Tran equivalent oil for my IH tranny/hydraulics because that is what all of the machines require and have been recommended by the respective dealers for the equipment.
   / transmission/Hydraulic fluid. Who's using what? #37
snoboy,
I agree with you, I'm an Amsoil person also, just got 2, 5 gallon buckets and will be doing my 50hr service in the next few weeks. /forums/images/graemlins/grin.gif
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
UNUSED HURRICANE STAND ON SKID STEER (A52706)
UNUSED HURRICANE...
2006 Kobelco SK210LC Hydraulic Excavator (A52377)
2006 Kobelco...
1265 (A50490)
1265 (A50490)
2014 CATERPILLAR 826G LANDFILL COMPACTOR (A51406)
2014 CATERPILLAR...
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
