sandman2234
Super Member
- Joined
- Dec 4, 2005
- Messages
- 6,649
- Location
- Jacksonville, Florida
- Tractor
- JD2555 and a few Allis Chalmers and now one Kubota
Many years ago, I built a trencher to keep from having to spend $40 to rent a trencher. Although the design has a few flaws, it works rather well considering who built it. On one of the first trips thru the backyard, it encountered a buried concrete block that previous owner had tossed into a hole to stop his dogs from digging. Never even slowed down the 13hp Ford 1100 I had pulling it. I found it when I went to lay the pipe. Later I needed to dig up a stump, and used it to cut the roots, but got carried away and did the whole stump.
The teeth are 1/2" by 3" flatbar, with stellite hard surfacing rods welded back and forth across the face.
Lately I have had a rash of shear pin failure, but have decided that the teeth might need sharpening. (and straightening the bent ones).
One to one gearbox, capable of digging about 11" as setup, but with longer teeth, I can probably extend that to about 18". The Ford 1100 won't pull it any deeper than that, and haven't had a need to try it with the JD2555 I recently purchase.
Chain was just put on there to transport from the backyard, don't ask what the rope is doing.
David from jax
David from jax
