trenching water line
   / trenching water line #1
project
Northern CA
What would be a good implement for trenching a water line without having the results of using a backhoe? Right now , all I have is a 4' box blade w/rippers. (which I haven't tried yet. Thanks
   / trenching water line #2
Try a subsoiler. I ran 140ft of power to a street lamp and it worked very well.
   / trenching water line #3
I have a King Kutter combo subsoiler/middle buster plow. Either one will dig you a 6-12" trench. Depending on soil conditions and your tractor hp, it may take several passes to get to the depth you want.
I used the middle buster to dig 12" deep tenches for 4" dia flexible drain pipes to route the gutter downspout flow away from the foundation. Used my 21-hp Kubota B7510HST in fairly soft soil and dug the trench in one pass.
Of course you have to scoop out the loose dirt with at trenching shovel.
   / trenching water line #4
Got rock?
   / trenching water line #5
Thats not fair!!!! We're tractoring here............
   / trenching water line #7
what does the code say for the depth of water lines in your area? that will have a great deal to do what implement to use.
   / trenching water line #8
You could rent a trencher. Around here you can get a walk-behind one for about $50 to $75 for the day.
   / trenching water line #9
Frank hit it on the head.
Jack Daniels Wall Art (A55853)
Jack Daniels Wall...
JOB BOX W/ 100K X 20' NYLON SLINGS (A54757)
JOB BOX W/ 100K X...
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A56138)
2017 FREIGHTLINER...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A55851)
2025 Kivel 42in...
