Trouble after rolling
   / Trouble after rolling #21
Don't be hasty here.
There are likely to be at least 2 comp rings and 1 set of oil control rings on the piston. A solitary broken comp ring won't cause the smoke. The oil control rings (scrapers) are not likely to be damaged.
If the cylinder was loaded with oil and you cranked the engine then you might have bent a rod, damaged the piston crown or damaged the head gasket, all of which are capable of causing low compression and subsequent smoke. Oil is theoretically not compressible and will act as a solid if it can't escape somehow.
Diesel comp testers are available at Sears, Snap-on, Harbour Freight, Mac Tools, Pep Boys and others. If all else fails go to a car dealer and ask when the Tool truck comes by and meet it then. Try rental places also.
Borescope's are good for looking at the piston crown and bore walls but I don't think they fit your current needs.
Testing the compression is a good place to start eliminating causes since you have clean air filters in place. It all may be as simple as an oil puddle in the muffler or intake plenum.
This advise is good for twice what you paid for it and comes with a money back guarantee.
Best of luck,
Martin
   / Trouble after rolling #22
The tractor, S470 Satoh Buck was my Dad's. Years ago, when he was still farming he had a not-so-smart employee drive the tractor from the farmstead to the house to mow. Dad said he told the guy to stay away from the road ditch. (narrow shoulder) The employee turned it over at the place Dad told him to stay away from. The engine suffered a bent rod. Sheet metal, radiator and steering wheel too. Engine was repaired, sheet metal banged out and radiator dobbed up. Probably less than a year later, Dad rolled it in the same place. This time the injectors were pulled when it was time to spin the engine over. It shot oil up on the side of the house. The last time, Dad rolled it again in the same place. This time, he was pinned under it until help arrived to get him out. An electric fence (barbed wire) was under Dad's rear end constantly reminding him how.. well, you know. A passing motorcycle saw his fingertips in the air and helped get the little tractor off. I don't remember any injuries in any of these rolls but I was either in college or had moved away. The tractor is mine now.
   / Trouble after rolling #23
Oliver28472,
Wow - Glad no one was seriously hurt. Thanks for replying.
Phil
   / Trouble after rolling #24
I mowed at the scene of the crime yesterday using the grey Mitsubishi 1450. Stayed on 4 wheels. Buck is in the shed with the blade on.
   / Trouble after rolling #25
When you cranked it over with oil in a cylinder it may have cracked the block or if your lucky only ruined the head gasket. You are probably burning antifreeze that is leaking into a cylinder when it sits after being hot. Does your coolant level change at all? If you take off the radiator cap while it is running (better to take it off before you start it ) look for continuous stream of bubbles that would suggest head gasket or cracked head/block.
Hope this helps
JB
   / Trouble after rolling #26
I flip engines over all the time /forums/images/graemlins/blush.gif when riding motorcycles off raod and trying to beat the clock. Just flipping the engine isn't a problem, letting is sit there and allowing a liquid to fill the cylinder is a problem. Another problem, more likely in the motorcycle world, is getting in deep water and sucking the water into the intake and then into the engine. Oil, water, gasoline, diesel, will all have the effect of being impossible to compress much. But you have to get a decent amount in the cylinder to cause trouble.
If you suspect that there is a liquid in your cyclinder. The first thing to do is get a wrench and try to slowly turn the engine over by hand through two revolutions. On the bikes, we use the kickstart for this. I have turned my dozer's diesel engine over by hand this way but a higher copmpression engine may prove too difficult and the next step is to remove the injectors.
The last thing you want to do for fun is remove injectors. Try the easy stuff first.
If the smokey engine is the only symptom I would keep running it to burn off the oil. If you are gaining or loosing fluids anywhere else or if the fluids are being cross contaminated then I would take it in.
   / Trouble after rolling #27
A simple compression test will not confirm a broken ring, you have to do a cylinder leak-down test using the proper gauge assembly that uses compressed air to do the test. Then, from the results of this test it will narrow it down to a cracked ring or piston, or a head gasket that is blown in a compression area only. A simple compression test will only show a major breach in a piston assembly or a valve not closing all the way(for whatever reason) or possibly a severly bent rod that will decrease compression in a diesel, or a huge chunk of head gasket missing, and it has to be done correctly for the results to mean anything at all. A compression check or a leak-down check will not pinpoint the exact component at fault, the results will only tell you whether you need to tear into the engine or not, and then again, that's only if the tests are done correctly. I think I would carefully monitor all gauges and fluids, listen very closely and run the engine awhile to see if it straightens-out.If not, I strongly recommend letting a real pro diagnose it to save alot of headaches & money.
   / Trouble after rolling #28
It could be as simple as a puddle of oil...blah,blah,blah...
so how is your grandpa recovering (nicely we hope) and how are you making out with this engine smoke? Enquiring minds wish to know.
Wishing you and your's all the best,
grandpa Martin
Thanks for your concerns. I posted an update on Grandpa in the Safety forum.
I ran the tractor most of Saturday, while mowing. I put almost 6 hours on the hourmeter. It smoked quite a bit when starting cold. After that it, only smoked when pulling hard uphill. I wish I had before and after rollover videos for comparison. It was hard to see smoke when it was warm. Today, when I started it up, it again belched out lots of smoke, and continued smoking a lot until about the same time the temp gauge started registering. It runs at reduced RPMs while smoking, and is interspersed with little burps of higher RPM and less smoke. The burps become more frequent, until the higher RPMs are more common and the periods of low RPMs and smoke become shorter.
The smoke appears white when viewed against the gravel, but bluish when you see it against the green trees, so I am guessing it is burning oil. The smoke fills the garage, and does not dissapate quickly. The smoke doesn't seem to be quite as blue as the oil that my 200,000 mile Acura puts out.
I will check the fluids regularly, and see if I can figure out what is happening with them. I am still open to ideas before I tear into the engine or take it to the dealer.
   / Trouble after rolling #30
I'd almost guess [ and guess it is ] at a broken piston ring.
Egon
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
(APPROX. 480BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 480BF)...
2010 Ford F-550 4x4 Venturo HT40KX 3 Ton Crane Mechanics Truck (A59230)
2010 Ford F-550...
KBH Tender Trailer (A56438)
KBH Tender Trailer...
Toyota 7FGCU25 5,000 LB Cushion Tire Forklift (A59228)
Toyota 7FGCU25...
2005 JOHN DEERE 310SG BACKHOE (A60429)
2005 JOHN DEERE...
