Troubleshooting Gutless Dodge 2500
   / Troubleshooting Gutless Dodge 2500 #31
i really like my 360 in my old dodge.
and it don't go thru caps or wires either.
it is on the 2nd set of caps and wires since new.. IE.. the set it came with from dodge.. and the set I put on 6ys ago.. same witht he plugs :)
runs good.
dash is beat, and interior kinda rough... paint peeling.. but starts and runs.
i've put a starter and water pump and radiator in it.. plus the usuale.. brakes..e tc.
oh yeah.. did repalce a fuel pump when she was 4ys old... um.. replaced core for aircon too.. hoses.. belts.. yadayada..
4wd works fine.. use it often.. :)
soundguy
I have to agree. I know I will get jumped all over for this but my boating buddy has a 2002 I think 1500 Dodge with a 360 5.9L. It would out pull my 2003 2500 with a 5.7L Hemi any day of the week. Not sure what gear, ect but it was a much better pulling motor than the Hemi I had.
I really think the guys are on the right track with the Cat. I would start by checking it first.
I have always been a big 360 fan. I just wish they would have built upon it for the trucks. Back in the late 90's I wanted a Durango with a 360 so bad but the money was never right on them. You could get a fully loaded Crew Cab F-150 or Expedition/Tahoe for about the same money.
Chris
Well I had to go pick my tractor back up yesterday. So before I left I did some of the simple checks.
Air filter's not new, but was still very clean. All plugs were snug. Double checked the transmission fluid. It is indeed clean as well.
Paid a little more attention to the symptoms on the return trip as well. At start up and low speeds it seems pretty solid. Pulling out of my driveway with the empty trailer it spun a little gravel. Under load with the trailer on the symptoms are worse and in fact I would say it almost "chugs" a bit with a bit of lurching.
I have a local mechanic who I've had do a few things for me that I can trust. I'll take it in and get him to look at the catalytic converter. If it's not too pricey, it may be worthwhile replacing it just as a bit of test before I decide to junk the thing altogether.
I've attached a pic of the truck in question. Just because we all love pics on here! ;-)
   / Troubleshooting Gutless Dodge 2500 #33
That is a nice looking truck! I hope that it is a reasonably cheap fix. I know on the Old Dodge Cop car that I had once I replaced the catalytic converter it ran great. At least you have your tractor back.
   / Troubleshooting Gutless Dodge 2500 #34
Wish my truck looked as nice as that one.:thumbsup::
Some folks modify the existing catalytic converter if it becomes plugged.:)
   / Troubleshooting Gutless Dodge 2500 #35
That is too nice of a truck to junk. Do you have inspections where you live? We do not. Hang on to your hat on the converter thing. I had to replace one on my last GM and it was over a grand.
Chris
   / Troubleshooting Gutless Dodge 2500 #36
Junk it???? Dang man. Where you at. I wanna see the rest of your throwaways!!
   / Troubleshooting Gutless Dodge 2500 #37
I gutted my convertor on my 97 dodge with the 360. It turned the check engine light on. It messed with the o2 sensor. Eventually replaced the convertor. But yes it is pretty common for them to come apart and clog
   / Troubleshooting Gutless Dodge 2500 #38
I should have know that messing with designed systems makes for bigger problems.:(:(
   / Troubleshooting Gutless Dodge 2500 #39
A simple test for the cat is to drill a hole in the pipe just infront of and just behind the cat..... start the truck and measure the exhaust pressure coming from each of the holes. The pressure should be the same.. a significant difference means that the cat is plugged.
   / Troubleshooting Gutless Dodge 2500 #40
You fellar's are just a little to young to have experienced the 383 or 440's.:D
oh no... im not THAT old.. but I DID have the good fortune to own both a 383 equipped and a 440 equipped Dodge chargers.... both of the "round taillight" variety...
GOD I wish I still had those cars!!!!
I used to street race the 440..... It had the Dana 60 with 4:10 and the 727... beat lots of "Daddy built" muscle with that old heap.... it was in primer and the only thing new was a carburetor and the valve cover gaskets!!!..
I've built and driven lots of fast cars in my life, but thats the only one that ever truly scared me... !!!
People never make mention of the old 383 and 440 anymore....Thanks for the trip down memory lane.....
2017 Chevrolet Tahoe SUV (A56859)
2017 Chevrolet...
VINTAGE GAS PUMP (A58374)
VINTAGE GAS PUMP...
2018 Komatsu GD655-6 Motor Grader, S/N 60403, PIN# KMTGD032PJA060403, Turbo Diesel Engine, 14' (A59076)
2018 Komatsu...
2014 Toyota Camry Sedan (A56859)
2014 Toyota Camry...
3PT 4 DISC TILLER (A58374)
3PT 4 DISC TILLER...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
