Truck winches
   / Truck winches
[I read first 4 pages of the thread]
I just got a HF 12k winch; apparently it'll pull over 400A. I'd imagine a 20k winch will pull more, unless it's going that much slower.
I plumbed mine with 2/0 pure copper to the front & back of my truck (particularly since the rear of the truck is 25' of wire away from the batteries; the wire alone cost 1/2 as much as the winch).
The winch can connect at either end of the truck using Anderson connectors; I replaced the winch-end wire with my coincidentally perfect length leftover pieces of wire (I'd bought 30' of wire for my CC LB truck, some goes from battery to front bumper, more from battery to rear bumper, and a final little bit from winch electric terminals to an Anderson connector; pics available).
@Hay Dude consider a hydraulic winch that's plumbed through the power steering. For a long time I had thoughts of going that route. Hydraulic winches have a much higher duty cycle than electric - most electric winches have a 5-10% duty cycle as they're just for getting you a little ways; the only downside is you can't winch with a dead engine, but that's got to be one of the more esoteric needs (example - mile marker).
I’d like to, but so far only Mile Markers does that and its 18K and very expensive.
Mile Marker does make a 15K winch for $1,050 but I don’t know if it’s any good…
Just looked at Warren Winches. All I can say is WOW! They are more than double the prices of everyone else's.
   / Truck winches #92
Even then, you wonder how long before wire melt on a 450 AMP draw?
Do you have a dual battery setup? That would be a relatively cheap solution and would negate the amp draw issue assuming you used appropriate sized cabling
   / Truck winches #93
I just got a HF 12k winch; apparently it'll pull over 400A... I plumbed mine with 2/0 pure copper to the front & back of my truck...
#00 is rated only 225 - 300 amps, depending on insulation type/temperature. It's probably fine if you're never doing 400A for more than a few seconds, just be aware. Have a fuse right at the battery on a rig like this, so if you start melting (or chafing) insulation, you don't light the place up like the sun.
The same #00 copper runs .092 m-ohm/ft, so you're dropping almost a full volt over each "leg" of the circuit at 400A over 25 feet, or 2 volts total if ground return to battery has similar resistance. That's a lot of drop on a 12 volt system (15%), but you're probably not actually hitting 400A draw frequently enough for it to be a real concern.
   / Truck winches #94
I mounted a 300amp marine type circuit breaker in the engine compartment on my HF Badland 12k winch despite the 400+ amp momentary draw rating.
Also acts as an on-off switch to keep power out of the winch even if the wireless remote gets activated accidentally.
I have yet to pop the breaker even when stalling the winch when pulling out a palm tree stump.
I would recommend one -a lot better than the chintzy serial/parallel multiple auto-reset breaker setup that's not waterproof and comes with the unit. Maybe the high dollar units have better circuit protection (?).
Here's the one I have:
   / Truck winches #95
I mounted a 300amp marine type circuit breaker in the engine compartment on my HF Badland 12k winch despite the 400+ amp momentary draw rating....I have yet to pop the breaker even when stalling the winch when pulling out a palm tree stump.
That makes sense. I'm not sure where you'd get the time/load curves for that particular breaker, but something like 2 minutes continuous draw would be a common time to trip at just 133% of rated current. Even at double rated current, it might take 60 seconds to trip a thermal breaker.
As always, size your breaker to the wiring, not the load. So, if running #00 with 90°C jacket, the 300A breaker is the perfect match, assuming the breaker also has 90°C terminal rating.
Ideally, you're running a breaker with both thermal and magnetic trip mechanisms. The thermal mechanism handles wiring overloads, to avoid melting your wire insulation or connectors, and the magnetic mechanism trips the thing at millisecond speed in event of a short-circuit. The magnetic trip mechanism is why you see "10kA" printed on the face of most residential breakers, they will instantly trip at 10,000 amps, no matter whether it's a 15, 20, or 30A thermal trip.
Good practice!
   / Truck winches
Yeah the Ram has dual batteries. I think all diesels have them.
   / Truck winches #97
The winch can connect at either end of the truck using Anderson connectors...
...most electric winches have a 5-10% duty cycle as they're just for getting you a little ways...
Have you looked at the rating of those connectors? They may be underrated, but still.
I have apparently never had a "most" electric winch. And I've done a fair amount of winch testing, both for work and in real life. Okay, the latter wasn't testing per se, but lots of actual use as necessary.
   / Truck winches #98
"Rated" is for continual use.
Surprisingly, winches get installed every day with 2awg wire (that's the norm). I'm pretty sure it's because of the 5% duty cycle, which as you noted "as long as it's not for more than a few seconds it probably qualifies.
A starter motor can pull 500+ amps. What gauge wire do you use for that? *Way* smaller than what's "rated" for that draw.
   / Truck winches #99
The SB350 connector is rated for up to 500A (continuous, of course).
Likely your electric winches had at 5% duty cycle, you just used them like everyone does and never bothered to check. Besides that 5% is at maximum load. Funny thing about winch duty cycles is that they match what the battery in most applications can deliver anyways, though obviously a dual battery setup can go longer.
   / Truck winches #100
Yep. As noted, those are continuous ratings. The difference between an owner wiring up their own winch and a manufacturer using under-rated wire on an OEM starter is that the manufacturer has the tools and wherewithal to do a transient thermal analysis, essentially determining the temperature rise during the time of applied current.
Like I said in the previous post, "probably fine... just be aware".
But the voltage drop I cited was real, and maybe more of an issue for someone running 25 feet down and another 25 feet back. 2 volts on a 12V system is a lot of drop right at the moment when you're demanding maximum pull. Getting at least one battery closer to the winch would resolve this.
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
UNUSED CFG INDUSTRIAL MH12RX EXCAVATOR (A51247)
UNUSED CFG...
2012 T650 BOBCAT SKID STEER (A51246)
2012 T650 BOBCAT...
2009 Ford F-550 4x4 11ft Flatbed Truck (A50323)
2009 Ford F-550...
Toro Workman MDX Utility Cart (A51691)
Toro Workman MDX...
UNUSED FUTURE QUICK ATTACH MAST W/ 29" FORKS (A51248)
UNUSED FUTURE...
