Milo
Platinum Member
- Joined
- Aug 7, 2006
- Messages
- 990
- Location
- Preston County, WV
- Tractor
- JD 3520, Ferris Z2100, Kawasaki Mule Pro MX, Honda Pioneer 520
I'm not ruling out a L2501 but I'll probably end up with one of the two above Kioti's due to the better lift and more creature comforts. Where I'm having difficulty is I keep going back and forth over the pro's and cons of the two. I would like having extendable ends on the lower arms and definitely the pin type link adjustment over turn buckles, rear remotes, 3rd function in the front, arm rest, and a couple other things that come on the SE and after adding them in the cost won't be that far apart between a 2610 and 3510 SE so price really isn't a big issue.
2610 HST
Enough power (probably just) to run 60" RC or flail. +
No DPF so no need to run at higher rpm to minimize regens +++
Manual clutch to more gently engage PTO seems like a plus. +
3510 SE HST
More power so even better running 60" RC or Flail ++
But not all that much at the pto. 2610HST = 21.5, 3510SE HST = 28, interestingly 3510 HST (not SE version) has 30.8. Why is that?
Factory installed options than I want, rear remotes plus all the extra SE features in addition to the ones that I would buy a la carte on the 2610. ++
Has anyone purchased either of these tractors but wished they would have gone with the other?
2610 HST
3510 SE HST
