Trying to remove Ball Joint assembly on Kioti 7320
   / Trying to remove Ball Joint assembly on Kioti 7320
I put pb nlaster on it yesterday even heated itnup to draw the lubricant inward like soldering a pipe. Not sure if that works with lube but it was worth a try.
I'd get that rubber boot out of the way. Then wrap the exposed cylinder with a very wet thick rag. Then carefully heat it up, keeping that rag wet enough so that the cylinder rod stays cool. I would be surprised if you aren't fighting locktite in the threads. You need longer wrenches or a pipe over the one you are pushing down on. Just a thought.
The tractor is fixed.
Thank you Engineer42. Used the wet rag and torch and a cheap set of service wrenches from Harbor Freight along with an 18 inch piece of pipe. Heated it up for about minute and half then Turned the wrench and it came loose.
   / Trying to remove Ball Joint assembly on Kioti 7320 #13
Glad it worked out. Good to see you have moved in.
Thanks. The house is great and I have an entire day to work on things around here tomorrow, because the tractor is fixed. Gonna organize my new storage unit and get my gym set up. That wil make this a very productive weekend.
Case 870 Agri King Loader Tractor (A59814)
Case 870 Agri King...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
2021 CATERPILLAR 299D3 SKID STEER (A60429)
2021 CATERPILLAR...
2019 BOBCAT T870 SKID STEER (A60429)
2019 BOBCAT T870...
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
