TSC PTO Post Hole Digger
/ TSC PTO Post Hole Digger #1
Brenttnhmby
Bought a TSC PTO PHD for my JD1070 last year while it was own sale. I want to use it to set some 4X4 post to fence in my garden. Need to now purchase the augar. What size augar should I purchase 6" or 9"? Someone with experience, please give me some advice.
/ TSC PTO Post Hole Digger #2
9 inch unless you know how to bore a perfect hole.
/ TSC PTO Post Hole Digger #4
For 4x4 (5" diagonal) a 9" auger works nice. You want to have some extra room to allow for the auger to drift a little during drilling. Then when you set the post you have a couple of inches all around to adjust the post to the straight line.
/ TSC PTO Post Hole Digger #5
I would buy them both,, I have a 6",9" and 12".. some of the cedar post I set I wish I had a 16".. but if you are only going to set a few 4" then the 9"...Lou
/ TSC PTO Post Hole Digger #8
If you've got heavy soil,back fill those posts with pea stone or crushed rock. they will stay put and stay straight. Should your lay out change, you can easily pull the posts and re use.
If I were buying only one auger, I would invest in a 12". Even with 4x4 posts roots, rocks and buried junk can divert all but the heaviest machines. Most 3PT augers use gravity to pull the cutting edge into the soil so it's right the first time period.
Another tip I've learned over the years is after you've reached your target depth shut off the PTO and pull the auger. Pull your tractor ahead and spin off the soil. This technique seems to provide a cleaner hole at least in heavy conditions.
2019 John Deere 9470RX Tractor (A63111)
2019 John Deere...
20in Single Cylinder Grapple Bucket Skid Steer Attachment (A61572)
20in Single...
2019 Nissan Sentra Sedan (A61574)
2019 Nissan Sentra...
2025 72in Hydraulic Grapple Rake Skid Steer Attachment (A61572)
2025 72in...
Lot of 4 10-16.5NHS Skid Steer Wheels and Tires (A61572)
Lot of 4...
2016 New Holland Boomer 47 (A60462)
2016 New Holland...
