turning 1985 dodge into a real workhorse
   / turning 1985 dodge into a real workhorse #11
Great project and perfect execution!
   / turning 1985 dodge into a real workhorse #12
I have larned once you have a dump you seem to have more friends, you know what same goes with a tractor. i have people calling me already for next year.
   / turning 1985 dodge into a real workhorse #13
Very impressive LD1. When I looked at the first post I thought, "there's a truck I'd put an engine and a flat bed on and use around the place". After another post or two I found out that's exactly what you did and more. Nice dump system as well! Personally, on a work truck I like a stick shift but to each their own.:D
Jay
Thanks for all the kind remarks so far.
The truck actually used to be a stick, but at one time I had a plow on it and an auto is a lot better for that purpose. I also swapped due to the 203-205 double t-case setup. The only tranny I had that would hook to the 203, which is the t-case that is first in-line, was the 727. All me NP standards were hooked straight to the 205's.
   / turning 1985 dodge into a real workhorse #15
That truck came out great, Its screaming for a cummins though , did you add lockers in the rears ? What a difference they make ! Anyway great job!
Not lockers but a Dana trac-loc posi in both the front and rear
Landoll Lowboy Trailer (A56438)
Landoll Lowboy...
2025 MMS MS36C (A53317)
2025 MMS MS36C...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2019 FREIGHTLINER WATER TRUCK (A58214)
2019 FREIGHTLINER...
2008 CAT D6T DOZER (A58214)
2008 CAT D6T DOZER...
2019 Peterbilt 520 Heil Side Loader Garbage Truck (A55973)
2019 Peterbilt 520...
