Ugly beads, critics welcome...
   / Ugly beads, critics welcome... #131
Oh I know, this is one powerful little welder:cool2:! It runs 10 to 15-AMPS hotter than my Lincoln V350-Pro. Now this is a comparison with the same joint prep, same type, and size rod.
GManBart yesterday I found some 1/8" ESAB Acclaim 7018. This morning I thought I'd see how it runs on the Everlast PowerArc 200ST.
The flat fillet was run at 90-AMPS.
The vertical up fillet was run at 85-AMPS.
The cap weld on the pipe was also run at 85-AMPS.
Very nice!
   / Ugly beads, critics welcome... #133
Thanks!;)
I really think ESAB consumables are a good fit with Everlast welders. The PowerArc 200ST does very well with ESAB's 10P-Plus 6010.
Ran a couple more fillet welds today....they all looked like this. I couldn't move any slower if I tried, so I'm wondering if the drag angle was too much and caused the pointy ends?
These were one after the other on the same plates, about 5" long each, and each used 2/3rds of a 7018 rod.
My first welding project....a brush screen for my dozer.
   / Ugly beads, critics welcome... #136
Hard to tell, without being there to watch you weld.
Really those welds don't look bad at all! Just wait until you get the PowerArc 200ST.
   / Ugly beads, critics welcome... #137
You are spending too much time in the middle of the bead , and stacking . Learn to roll up and down that joint , and soak it in . SA is the man .
Thanks...I'm hoping the 200ST ships today! :D
Thanks....I'll give it a try. I was moving up and down a little bit, but probably not enough. I'm going to play with the rod drag angle, see what happens, then try more up and down (I like to change only one thing at a time when possible).
On a positive note, I've tried using the grinder with a cutoff disc to reuse a few of the plates I've welded on previously, and I gave up....the welds were solid enough, and penetrated deep enough that I would have been there forever. I think that's a good sign!
   / Ugly beads, critics welcome... #140
Yes it is . Can you see , that is my biggest problem . You have got to be on top of that weld .
2007 Club Car DS Gas Cart (A55853)
2007 Club Car DS...
JOHN DEERE 331G SKID STEER (A52707)
JOHN DEERE 331G...
16ft T/A Flatbed Trailer (A53424)
16ft T/A Flatbed...
2017 Ford E-450 LP Handicapped Bus (A53422)
2017 Ford E-450 LP...
John Deere 3025E (A53317)
John Deere 3025E...
2019 Ford F-150 Crew Cab 4x4 Pickup Truck (A53422)
2019 Ford F-150...
