Ultra Low Sulfur Diesel Fuel Warning
   / Ultra Low Sulfur Diesel Fuel Warning #81
</font><font color="blue" class="small">( Mad:
To be sure it won't be a one day phase in. Pup is wrong in the statement of destroying the engine. What will actually happen will be the same as running tetra-ethyl lead in a gasoline engine equipped with a catalytic convertor....the sulfur will render the catalyst ineffective. From what our factory mechanics tell me, however, is that the cat's will actually rejuvenate themselves over a period of time with a steady diet of ULSD.
The whole problem is that the overall efficiency of Rudolph Diesel's engines are going backward with the addition of emission hardware. Caterpillar and DDEC are predicting a 15-25% reduction in fuel mileage in 2007 engines as opposed to 2006 engines which just happen to be around 15% less efficient as their pre emission counterparts as it is.
)</font>
Daryl,
I cant say your facts are incorrect, but their not a fair blanket statement.. You wont melt pistons or valves, nor will you throw a rod or anything of that sort from running ULSD.. However, the emission components you mention are more than just cats.. The engines themselves are changing in order to accomplish the lower emission standards.. The fuel is just a portion of it.. Some MFG's may not need to make major changes, but others will.. Just for an example, the Navistar built 6.0L in the Ford trucks was designed for emission compliance.. Thats why the 7.3L went away.... The 6.0L design incorperated a similar injection system, but added an EGR and variable turbo(among other things) to meet emissions.. The 6.0L will not meet the '07 standard.. You wont see an '07 Super Duty with a 6.0L in it(maybe an '06 built in '07, but not as an '07 truck).. The new engine had to change to common rail and add more coolers and another turbo..
So, back to your point you are correct that the new fuel wont destroy your engine.. But they are changing to meet the standard.. The trucks and tractors already out there will be fine...Even a few years ago, we had issues with the cats clogging from too high a sulfer content in the fuel... Run LSD and it fixed itself.. The newer engines will require a particulate filter wich is like a super cat.. It actually needs to be baked to clean it.. Some will require it for maintenance.. There is also a strategy in the EEC system that will run it rich in order to burn it off w/o extra maint.. There is also new tech coming in the form of urea injection to further reduce the emission levels.. One can do allot of damage with the wrong fuel, its up to them to decide how much is required to "destroy" it iin their mind... It I needed to pay $5k to repair my engine/emission system because of the wrong fuel, I can see where that could translate into " it blew my engine up" even though it may not be technicaly so..
Also, Bio diesel may not be (across the board) damaging... But, wether anyone believes it or not, there are concerns from it.. It may just be bad batches, but that must be taken care of and eliminated before it becomes widely accepted.. There are lobyists on both sides, so most of the info out there is propaganda... I can promise everyone, this is not a lie or an oil company conspiracy.. Groups have been formed to study the effects and what needs to be dont to eliminate them..
And lastly, the picture shows what I and others stated.. The LSD is being sold at that station, they need a lable to inform the consumer that if they put it in their truck designed to run ULSD, it can severely damage the engine(components)..
   / Ultra Low Sulfur Diesel Fuel Warning #82
)</font>
Daryl,
   / Ultra Low Sulfur Diesel Fuel Warning #83
</font><font color="blue" class="small">( Don't you think that if you have heard about it (the super- hydrogenation of aromatic hydrocarbon rings in the middle distillate fraction results in less natural inherent lubricating ability once the sulfur is removed via this methodology) that the oil companies who designed and manufactured the multi-billion dollar catalytic apparatus might have also heard about it?
)</font> `
Asusual.. a side step instead of an answer. It would have taken 3 seconds to type a yes/ no answer.. instead I got a red herring.. reminds me of gsxr1100... couldn't get a straight answer out of hime the entire time he was on her.. before he got himself removed...
the players may change.. but obviously.. the story never does.. /forums/images/graemlins/confused.gif
Soundguy
   / Ultra Low Sulfur Diesel Fuel Warning #84
)</font> `
Soundguy
   / Ultra Low Sulfur Diesel Fuel Warning #87
</font><font color="blue" class="small">( Sky Pup:
In regards to your post #885549 and the statement from you that ULSD will destroy diesel engines manufactured after 01-2007 is completely false.
In fact, the engines themselves will not be any different internally that the engines produced this year, however, the emissions hardware will be and the introduction of fuel manufactured before 01-2007 will degrade the emissions hardware, namely, the catalytic convertors. )</font>
Thanks Darryl, I have known that a fact for a long time! /forums/images/graemlins/wink.gif
   / Ultra Low Sulfur Diesel Fuel Warning #88
   / Ultra Low Sulfur Diesel Fuel Warning #89
<font color="blue"> Don't you think that if you have heard about it (the super- hydrogenation of aromatic hydrocarbon rings in the middle distillate fraction results in less natural inherent lubricating ability once the sulfur is removed via this methodology) that the oil companies who designed and manufactured the multi-billion dollar catalytic apparatus might have also heard about it? </font>
<font color="pink"> Asusual.. a side step instead of an answer. It would have taken 3 seconds to type a yes/ no answer.. instead I got a red herring.. reminds me of gsxr1100... couldn't get a straight answer out of hime the entire time he was on her.. before he got himself removed...
Soundguy </font>
Yes, the fact that the organic chemists and petrochemical engineers who produced the sulfur removal hydrogenation catalytic chemisty have known about this all along means that by the time you have found out something about it, it is not a problem except in your imagination.....
How's that for an affirmative BIG YES SIREEE!!! /forums/images/graemlins/grin.gif
BTW Sound, how long was he on her??? /forums/images/graemlins/blush.gif <font color="blue"> </font> <font color="pink"> </font>
   / Ultra Low Sulfur Diesel Fuel Warning #90
Soundguy </font>
2007 JLG 600S TELESCOPIC MANLIFT (A52705)
2007 JLG 600S...
2025 Unused LandHero LDH-T460XX Ride-On Mini Skid Steer (A52377)
2025 Unused...
2015 Jeep Compass SUV (A50324)
2015 Jeep Compass...
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
Biljax Indoor Scaffolding (A52377)
Biljax Indoor...
2019 PETERBILT 579 TANDEM AXLE SLEEPER (A54313)
2019 PETERBILT 579...
