UNIMOG RESTORATION UPDATE + PHOTOS
   / UNIMOG RESTORATION UPDATE + PHOTOS
Hows this for shifters, There are 6 of them!
Had to get one of the Kubota in there somewhere! Here I'm moving the Case deck that was on the back. The frame for the deck is 1 1/4 thick! /forums/images/graemlins/shocked.gif The tractor was a little lite in the back end when moving this! But it picked it up with no problems! /forums/images/graemlins/smile.gif
   / UNIMOG RESTORATION UPDATE + PHOTOS #23
Von,
thanks for all the photos...looks like you are hauling on getting that Mog working! And that cab doesn't look quite as bad as you say...OK so I bet the bolt-on pints are rusted though.
Even though you are in NY and I am down in Ohio I'd be happy to help....f you need some real heavy lifting and your Kubota can't do it....I'd be happy to bring up my Deere /forums/images/graemlins/grin.gif
Peter
   / UNIMOG RESTORATION UPDATE + PHOTOS #24
Von,
I am not familiar with a Unimog can you give us some history on the vechical? What was the target market, who made them, what were they used for, are they still produced, why 6 shifters??? Any other details for the uninformed. Thanks.
   / UNIMOG RESTORATION UPDATE + PHOTOS #25
6 shifters... Let's see, I think I figured out a few, but not all /forums/images/graemlins/shocked.gif
1-main tranny
2-4wd in/out(transfer case)
3-hi/lo range(transfer case
4-pto
5-dump bed rasie/lower
6-over/under drive
4 out of 6 correct?
   / UNIMOG RESTORATION UPDATE + PHOTOS #26
yankee fan,
Try doing a Google search on UNIMOG. There's more information than you could possibly shake a stick at.
They are/were made by Mercedes Benz. I believe that
they were originally designed as a military/heavy industrial vehicle. They are still produced, although they have evolved a bit from the original. They still have superb off-road capabilities.
Well the cab is off! /forums/images/graemlins/laugh.gif Had to use my tractor and my neighbors JD 755 to lift it straight up with the loaders. Didn't get any photos of the cab coming off, I was too busy with the loader. But here are some with it off.
Here is the cab on its own. Boy it looks alot smaller off of the frame.
Here is a good one that shows why I need to replace the cab! /forums/images/graemlins/frown.gif
Here is a closeup the the powerhouse! What a beast!
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
2010 Ford F350 Super Duty, Super Cab, CM Flatbed (A52384)
2010 Ford F350...
UNUSED DB500 DUSTLESS BLASTER (A51248)
UNUSED DB500...
2011 DOOSAN ALL TERRAIN FORKLIFT (A53426)
2011 DOOSAN ALL...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
HURRICANE 6' X 11' CONTAINER (A51248)
HURRICANE 6' X 11'...
