use of rototiller BX24
   / use of rototiller BX24 #1
rnbrn21
Honeoye Falls, NY
Kubota BX24
I am considering using a rototiller on my BX24. Seeing as how the 3 point hitch does not have any down force I was wondering how well it would work. Does any one use a rototiller with their BX tractor?
   / use of rototiller BX24 #2
I use a 5ft tiller on my BX2200. Works great. The weight of the tiller is @ 400lbs. No down force is needed. Tiller digs down as far as I let it.
   / use of rototiller BX24 #3
Only very, very few Three Point Hitches incorporate down force, which is only helpful when tractor is NOT moving such as using a mounted auger. Even when using an auger, the "help" is limited.
When the tractor is moving, Newton's Law of Equal and Opposite Reaction means downforce lifts rear of the tractor, decreasing traction. No net gain to you.
WEIGHT is key to cutting effectiveness with all ground contact implements. Buy HEAVY.
A 40" to 54" PTO powered roto-tiller works fine on any BX size tractor.
LINK TO T-B-N ARCHIVE: "TILLER ON BX": https://www.google.com/search?clien...oe=UTF-8&gfe_rd=ssl&ei=luSGVoXKLIOd-AXLg6mwBQ
Here is tiller reference pricing: pto tiller in Heavy Equipment Attachments | eBay
   / use of rototiller BX24 #4
Consider a reverse-rotation tiller as they may help dig deeper. Weight is your friend. Recommend Woods or Land Pride.
   / use of rototiller BX24 #5
I have a Countyline 4' tiller made by Behlen (branded Countyline) that I bought at TSC for my BX25. It weighs a ton, but the Kub picks it up without a problem. The website says 595lb and I bought the tiller last spring so I'd guess that's accurate. I also have a Speeco Cat 1 quickhitch so that adds weight (70lbs?).
The tiller is USA made, but has Chinese gearboxes. I'm not sure if the top gearbox can be rearranged in order to make it reverse till. I'd hate to have to take all the tines off and swap direction if I wanted it the other direction.
For forward till vs. reverse till I think I prefer the forward till. If it hits a big rock it goes out the back and it's usually on the top of the soil. I found a 3' piece of rebar in my sister's yard last fall. It caught in the tines, but didn't bend anything on the tiller.
As far as performance I'm glad I didn't buy a bigger tiller. 4' keeps the engine loaded plenty. When I till it's usually with the skids fully raised so it's all the way in as far as it will go.
Attached are some pictures of my setup that a friend took a week ago when I tilled his new yard. The tiller is set on the second hole.
1979 Trail 40 ft Hopper Bottom Grain Trailer - Dual Grain Doors and Leaf Spring Suspension (A46877)
1979 Trail 40 ft...
2021 John Deere 333G Two-Speed Hi Flow Compact Track Loader Skid Steer (A44571)
2021 John Deere...
2007 JLG 600S 4x4 Telescopic Boom Lift (A44571)
2007 JLG 600S 4x4...
2003 Chevrolet Express 14FT Box Truck (A44571)
2003 Chevrolet...
Hydraulic Ram (A47484)
2018 Ford Escape AWD SUV (A44572)
2018 Ford Escape...
