</font><font color="blue" class="small">( strange, usually draft control only raises a bit )</font>
It raises proportionaly based on how sensitive you have the draft sensing hytrol handle set. Remember.. the 9n was not designed with a rotary mower in mind. The weight of the mower on the draft 3pt was a ballancing act at best.. the slighetest variation in ground would make minor shock loads onthe 3pt.. the draft hyds interpreted this as more draft on t he lift, and then it would in turn lift the mower. An out of adjustment quadrant and internal linkage greatly exagerated this to the point that you only had float and transport mode. The lift is actually simple to adjust. Takes about 15 minutes of work.. minus pulling the top cover.. also takes a special jig that is no longer available by NH.. but is available aftermarket. My -well maintained and serviced- 2n has a correctly functioning lift. Like I said also.. there were position control feedback external add on parts to make the ferguson lift system function like a real position control. The most popular one was the 'fergy positioner'. There are new aftermarket units called the 'zane thang' made by a retired ford mechanic named zane sherman.
</font><font color="blue" class="small">( then there was the brush hog pushing the whole tractor even when you step on the clutch.... another "less than awesome" bit of design work requiring additional overrunning clutch )</font>
Please.. give me a break... 66 years ago.. the single plate foot operated clutch wasn't even in complete use by all tractor manufacturers.. many still had hand clutches for pete's sake.. My 1950 JD-B has a hand clutch...
In any case.. live pto was not common untill the 50's.. though there were aftermarket units to correct that. Dearborn made a 'live pto' that fit the 8n and NAA.. was more or less a hyd clutch pack... In 55 a 2 stage clutch became standard on all X6X models.. and anything with an SOS tranny with a model number in the X7X or higher sos variants had independent pto. Remember.. we are comparing 66 year old technology to current technology.. so the comment of you throwing back the 'awesome design' based on a tractor having 2stage clutch in the here and now, vs a design from 66 years ago is laughable.. heck.. oil filters were just becoming available on many tractor engines inthe late 30's.. and those were not even full flow units. Your comparison is about as good as compairing pre- ww2 meds with current meds.. especially the lack of good antibiotics..etc...
And.. there are plenty of more modern tractors that still are non live pto...years down the line..
</font><font color="blue" class="small">( then there were those nasty points that would stick and corrode )</font>
Again.. a maintenance and care issue.
My 2n is stillont he same set of points I purchased it with..no adjustments.. My cub is on the same set of points i purchased it with.. I have honed then once. My 8nis ont he same set of points I purchased it with.. they have been honed once. my NAA is on the same set of points I purchased it with.. no adjustments. My 660 is still ont he same set of points I purchased it with. they have been honed once. My allis G is on the same set of points I purchased it with, and per the seller, they are from when he overhauled the engine in 1991, and have only been honed and adjusted.. never replaced. My JD-B magneto has only had 2 sets of points.. one was the original.. the other was put in by the original owner a year before he sold it to me...
Most problems I see with points come from ham handed non-mechanics that use dirt feeler gauges, overtighten hold down screws.. don't replace dust caps, intorduce contaminants into the distribuitor body, and who don't properly lube the leading edge of the rubbing block, thus leading to fast wearing lobes and then fast wearing rubbing blocks and rapidly changing points gaps which eventually close up, pit arc and burn. Leaving the ole' ignition switch on allnight isn't too friendly to the points either..
Next failure is the 'sandpaper' or worse yet 'emory cloth' used to file points. Heck.. even the average flat file is not suitable to 'dress' or 'hone' points There is a specific ignition file that is suitable for dressing points... it should be kept clean and you should always keep a seperate feeler gauge for points work only.
I see people complain about points all the time. i simply don't see the problems.. except for lack of maintenance.. or lack of understanding. I live in hot humid rainy florida. My points see the worst of it ... still.. no problems.
Next set of faults comes from the same non-mechanics who don't know how to properly match system primary current and primary resistance thru the use of the correct ballast resistor if needed.
My favorite quote on the issue of electronic ignition vs breaker ignition was that when your ignition module failed out in the middle of no where..you walked home. When your points burnt out inthe middle of no where..a fingernail file.. you might still get you home...
</font><font color="blue" class="small">( whose Idea was it to put the distributor in between the engine and the radiator anyway? talk about "Awesome design.... I've had several 8Ns, even a couple good ones one even had the distributor where it could be serviced )</font>
I actually prefer the front mount distribuitor. I find it WAY easier to service than the side mounts. How many other tractors do you know where you can remove the distribuitor and work on it inthe comfort of your barn or garage and then pop it back on and be 100% certain that it was backin right ever time. The front mount distrib was held on by 2 bolts.. it was about a 15 minute job to pull the distrib change the points out, gap them.. then static time it with a straight edge using the manual, and then reinstall it.. that included a cup of coffee and the walk to and from the barn. The distrib was driven by an offset tang off the cam.. it only went back in 1 way.. no way to install it out of time unless you used a hammer. Can't do that with a sidemount by any stretch of the imagination. So yes.. i would call that 'awesome design'.. cause who likes to set there and re-time a tractor!
</font><font color="blue" class="small">( just trying to make a point about being overly critical )</font>
i don't feel I was being overly critical. i feel the 3pt design in question is overly simple.. to the point that it resembles much more like a retrofitted 3pt setup usingn a remote style spool control hooked to a cylinder lifting the 3pt..( kinda like 3pt conversions for non 3pt tractors..) I'm sure cost was a factor inthe complexity.. or lacktherof.
</font><font color="blue" class="small">( In fact I have replaced many old fords with Jinma/farm pro tractors and everyone likes the Jinma better, better fuel economy, 2 stage clutch, you can raise the lift with your foot on the clutch even.
)</font>
late 52 corrected the non live hyd issue.. late 54 corrected the 2 stage clutch issue enmasse., as an option,. though as imentioned.. a live clutch addition was available for the 8n.
</font><font color="blue" class="small">( Again it works, if you set the stops correctly )</font>
I guess that is the part I have the issue with. The fact that you have to set the stops in the first place...In retrospect... I guess that's part of the tradeoff.. part and parcel I guess.. more of a hands on unit.. big savings at the pocket book.
Soundguy
