Using a Forward Tiller in Reverse?
   / Using a Forward Tiller in Reverse? #11
Yes.
Right, the tines are also reversed/rearward with conventional tiller means the tines are cutting on their backside.
The soils and trash is pushed in the direction of travel.
There are videos on reverse tillers in operation.
I said this wrong. In all cases the cutting edge is either cutting new ground from the top down or from the bottom up.
It's getting complicated folks and it shouldn't be.
You're right, we have made it complicated, and just to be ornery, I will make this statement:
A reverse tine tiller will rotate clockwise when viewed from the left side of the tractor, the left side being as viewed from the tractor rear. :)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2012 NORAM POWER SYSTEMS 100KW GENERATOR (A55745)
2012 NORAM POWER...
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
2015 Goose Neck Cattle Trailer (A53317)
2015 Goose Neck...
1992 Norris Long Basket Trailer (A60460)
1992 Norris Long...
2012 DIAMOND C  40FT GOOSENECK TRAILER (A58214)
2012 DIAMOND C...
