Value leader 6' finish mower- first use
   / Value leader 6' finish mower- first use #1
Sackett2
Platinum Member
Eugene, Oregon
Montana 4344HST
Well, 1/2 of our time here seems to be telling each other of our mishaps and adventures. Today's story is of my first use if my new Value leader 6' finish mower.
I got it off ebay from Betstco at a steal, 475. Its been setting on my trailer for well over a month and today the sun was out and its time to try it. So I unloaded it and put it in position. The first thing I noticed was the 3 point arms didn't go low enough. So I had to lift the mower onto the pat's easy change. Got the 3 point attached and put on the pto shaft. was having some difficulty getting the pto to line up so had to get a pinchbar to turn the mower over a bit.
OK now the mower is hooked up and setting on its wheels on asphalt. It sets low and I was thinking this may be a close cut. Had to drive the tractor to my brother-in-laws place and try a test mow.
Got there and idled down and turned on the pto- thunk and the engine died. hmmm, that's not right. restarted and idled up a bit and tried again; the tractor didn't die, but the pinch bar sailing off into the grass caught my attention. I forgot to remove it when lining up the pto shaft. a small dent in the deck and a broken shear bolt.
Found a temporary smaller bolt, as the area I had to mow was small. installed it and tried to mow. the mower was scalping the lawn and no matter what I did I couldn't get a consistent cut. I hacked and tracked the lawn up and got 'er done and took the mower home to see if the wheels could be raised at all. On the way home I set it on the gravel driveway and the deck was hitting.....
Raised it up and examined the wheel/strut assembly's. Found 3 spacers and figured out you can move them from the top to the bottom and get more lift. that done i was a bit happier, but kept staring at them. the spring was put on the top, and was providing a spring option in the wrong direction. so took them apart again and relocated the spring to the bottom and provided the mower with 2-3 inches of lift, and wheels that can now move with the terrain.
So wait for the next growing and see what it does this time.
Kubota KXO40-4 (A53317)
Kubota KXO40-4...
2023 Spartan RTHD Zero Turn Mower (A59814)
2023 Spartan RTHD...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
2020 DRAGON ESP...
2018 Ford Escape 4WD SUV (A59231)
2018 Ford Escape...
2019 RAM 5500 Bucket Truck with Versalift VST47 Boom - Cummins Diesel - 4X4 - Automatic (A56438)
2019 RAM 5500...
