Flail Mower value leader flail
   / value leader flail #21
Easier to replace the bolt than belts (cheaper too)
Yes, but the belts don't break from a brief shock load, they just slip a bit and then the tractor stalls if the load is not removed. I have broken many shear bolts on a bush hog PTO and hated it as it always left me with a 15 minute maintenance task in the middle of a field. Having belts slip occasionally is pretty benign.
Belts of course do eventually wear out and when they go it can be dramatic. However, I wouldn't say that in my case the belts failed due to a shock load. They were about three years old and I was mowing in heavy brush when they started to fail. One apparently had disintegrated and then the other two started slipping/smoking/smoldering. I assume that is how mower belts eventually fail after wearing out and didn't think it was due to a simple shock load.
   / value leader flail #22
I often wondered if that wouldn't be a good reason to buy a Bush Hog brand finish mower instead of a bush hog for HEAVY large lawn areas. You have the belts that can slip when you bog it down too much. I too hate the shear bolt process and like a slip clutch. Drawback is they're not tough like a stupm jumper type bush hog. I found a 90" Bush hog finish mower with hydraulic height adjust for $1,500. Tough lookiing mower, but I'm still holding out for a 8' flail.
Couple of my customers want to know when I'm coming out and my puny 5' bush hog is on it's death bed. :(
I gotta make a move here soon.
   / value leader flail #23
Why not just add a slip clutch to a bush hog? AgriSupply sells them for about $80. Easy to install on the PTO shaft (just make sure you order the right style to match your PTO shaft and gearbox the first time and don't ask me how I know).
   / value leader flail #24
Because my bush hog is way too small and isn't worth more than ~ $200. I need a bigger newer mower.
   / value leader flail #25
Gotcha. Have you looked at the twin spindle Bush Hog rotary cutters? They are about seven or maybe eight feet wide. They seem like a nice compromise for field mowing as they are wider than a typical Bush Hog of caparable weight/cost but they are much tougher than finish mowers.
   / value leader flail #26
I had my heart set on that exact mower, the SQ84T, but I was told the hitch frames are light duty at best and I'd really like to be able to adjust height from cab. Really I think I'm a 8' flail mower candidate.
   / value leader flail #27
That makes sense. Too bad 8 foot flails are so expensive.
   / value leader flail #30
I keep thinking of adding a slip clutch to my flail.
Regarding shear vs belt slippage, I'd wonder about the stress factor on the gear box. I've noticed with mine, that the PTO shaft freely rotates clockwise, meaning there may be some slack before engaging. I'm guessing that when I get sloppy, that shear bolt snaps before the stress gets fully transferred to the gear box. Wonder how stressful it might be on the gear box if the weak point was beyond, ie at the belts?
On my Rhino cutter, the shear bolt was a through the shaft type. The Hanmey shear is quite different, a bolt that runs parallel to the shaft. So where the former breaks by shearing across the bolt diameter, the Hanmey twists along its axis. Hope that makes sense.
I really do need to be more mindful of my engagement technique, guess I got lack in my brushhog days. :laughing:
David
2012 Dodge Ram 1500 Tradesman Crew Cab Pickup Truck (A53422)
2012 Dodge Ram...
2008 Ford Focus Sedan (A53424)
2008 Ford Focus...
2018 Freightliner Day Cab, Detroit Diesel, Auto (A52384)
2018 Freightliner...
2015 Ford Explorer AWD SUV (A55853)
2015 Ford Explorer...
2015 Freightliner M2 106 Terex BT2047 10-Ton Crane Truck (A51691)
2015 Freightliner...
2023 Sundowner Rancher Express 24FT Livestock Trailer - All-Aluminum Stock Hauler (A55302)
2023 Sundowner...
