Value of 430?
   / Value of 430? #31
Yes, the deck hangs off the tractor. Cutting height can be set from 2"-6" (Set by the depth stop adjuster on rear of the tractor by rockshaft). Wheels are to be 1/4" above the ground when at cutting height & level (pages 12-15 of the Owners Manual OM-M88418 K5).
   / Value of 430?
Don't have the manual, haven't even changed oil or put new blades on... (been fixing bigger tractor to cut rest of farm with)
I would have thought it rode the ground like my rear finish mower so that's my ignorance. The wheels dig in every now & then and I've been scratching my head as to why..... I guess I now know why!
   / Value of 430? #33
Richard
The routine to level the deck should go like this...
1. Air the tires about 8-10 psi rear and 15-16 psi front.
2. Raise all four deck wheels to highest setting temporarily.
3. Set a height level to 2-1/2 inches (for leveling purposes)
4. On a flat surface and a block 2-1/2 inches depth, adjust right and left blade tips to just touch that block, and turn the turn-buckles to accomplish this setting. (be sure blades are not bent).
5. Check front to rear settings with your 2-1/2" block, and by adjusting the front bail, make the center blade front tip 1/4" lower than the rear tip of that blade.
6. Now drop the four deck wheels to where they are about 1/4" to 1/2 " clearance from your flat surface for whatever height setting you want to mow.
Should give you a very even and flat mown lawn now.
   / Value of 430?
Very nice, thank you! Going to copy/save that in a folder.
(1) 275 Gallons of Aluminum Brightener (A51573)
(1) 275 Gallons of...
2012 Ford F-550 4x4 Versalift VO36I-01 36ft Insulated Bucket Truck (A52377)
2012 Ford F-550...
(4) Drums of Mixed Fabric Softener/Detergent (A51573)
(4) Drums of Mixed...
2024 JOHN DEERE 8RX310 LOT NUMBER 77 (A53084)
2024 JOHN DEERE...
2022 Polaris Ranger 4x4 Utility Cart (A51691)
2022 Polaris...
FAE UML/SSL 150 VT QUICK ATTACH HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
