Value of this forum
   / Value of this forum #1
funpilot
Chesapeake, VA
PT 425
Well, I finally got around to tightening that bolt I had to buy the monster wrench for....and it was very loose. Never would have known to do that if it wasn't for you guys here.
   / Value of this forum #5
I am a little curious also about the tightness of that nut. Were there any instructions about how to tighten that nut, or did you call Terry. Or did you go by what someone said on this forum? How did you know when it was right?
   / Value of this forum #6
   / Value of this forum #7
I have been wondering about that too, concerning possible damage to the joint or stripping the thread. I put my foot on the back tire and put some real torque on mine. After wards I started to think about this. How tight is too tight?? /forums/images/graemlins/confused.gif
   / Value of this forum #8
   / Value of this forum #9
</font><font color="blue" class="small">( I have been wondering about that too, concerning possible damage to the joint or stripping the thread. I put my foot on the back tire and put some real torque on mine. After wards I started to think about this. How tight is too tight?? /forums/images/graemlins/confused.gif )</font>
I've attached a torque chart for standard SAE hardware bolts. Note two things:
(1) Values above the line for small bolts are in inch-pounds not foot-pounds and
(2) Lock nuts are to be torqued at 65% of these values per the footnote on the chart
   / Value of this forum #10
2016 Ford F-150 Ext. Cab Pickup Truck (A50323)
2016 Ford F-150...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
UNUSED CFG Industrial H15R Mini Excavator (A47384)
UNUSED CFG...
2014 International Durastar 4300 Terex BT3063 30,000lb 63ft Crane Truck (A50323)
2014 International...
2015 INTERNATIONAL PROSTAR 122 SLEEPER (A51219)
2015 INTERNATIONAL...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
