Vane pump for splitter
   / Vane pump for splitter #1
rusty32
Hi , been a lurker for some time now. We heat are shops at work with wood, I work at a recycling/garbage center. During the winters we store most wood inside to keep it dry. I would like to build an electric log splitter for use indoors, mostly constructed out of stuff leftover from are garbage trucks and things from our scrapyard. We recieved a brand new bosch/rexroth vane pump in scrap 30gpm @1750 rpm and 2000psi. From what i found it would take 40hp to run this pump right which we get thoose in the scrap yard too. But would a vane pump work well in this situation. Thanks
   / Vane pump for splitter #2
Yes a vane pump will work. Do you need the 30 GPM flow rate? If not and you can get a 1200 RPM motor this would lower the flow rate to around 20 GPM and your HP 25 - 30.
Just keep the oil clean since vane pumps are little more sensitive to dirt than gear pumps.
Roy
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2018 FREIGHTLINER...
iDrive TDS-2010H...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
Peterbilt Tandem Axle Road Tractor (A47477)
Peterbilt Tandem...
Wacker Neuson RD12 (A57148)
Wacker Neuson RD12...
