Virnig Snowplow
   / Virnig Snowplow #1
Glowplug
Veteran Member
3rd Planet from the Sun
Kubota M7040HD
I know the topic of snow removal has been discussed to death on this forum. I figure probably the two best ways for snow removal are either a front-mounted snow blower or a dedicated snow plow blade attached to the loader. I have looked at Meyer snowplows designed for tractor loaders on their website and they look very promising. But, does anyone have any experience or knowledge of Virnig snowplows? I found them on the internet.
Here they are: Virnig snowplows
   / Virnig Snowplow
I have heard a great deal about Meyer snowplows, especially for trucks. They seem to have a good reputation. But I have never heard of Virnig. I would love to have one of the two but I would have no clue what a setup like that would cost. I would bet a pretty penny though.
   / Virnig Snowplow #3
Those look like real heavy duty skid steer plows, the smallest one is 84" and weighs in at 1,190lbs.
What tractor do you have to put it on?
You might want to look at Curtis also...
Curtis - Tractor Loader Blades
   / Virnig Snowplow #4
Good idea, but as a tractor owner who can only deal with about 600lbs in my loader, I can't find much to work with. Still, I get a sore neck from looking over my right shoulder all day long, working with a rear blade to move snow. If I had a removable front bucket, then maybe I could mount a front blade that would be big enough to do some good. Maybe it won't snow too much this winter?
   / Virnig Snowplow
You're right. The Virnig plows look like serious heavy duty deals. I bet they'll result in your wallet being not too heavy duty as well. I don't know. But comparable Meyer snow plows weigh about half what the Virnig does. The Meyer plow looks like a more reasonable set-up unless you're a professional.
   / Virnig Snowplow #6
Good evening Varmit.
I hear you about the sore neck,but after the first winter of useing rear blade to plow I got my crayons out than did some hot glueing on second hand plow from auction.
Pull pin and and bucket ready to use,and one can make some mighty high snow banks.
11 years w/this setup and only replace the mailbox twice. :(
   / Virnig Snowplow #7
Speaking of front mounted snow plows....anyone have any experience with the plow that Aiken trailer sells? I'm being lazy here and not searching for an existing thread....and please don't yell at me if everybody thinks I'm hijacking the thread.
I was looking at the Aiken 'Snow Champ' plow but it'll cost $1300 or so with shipping. Seems to be a whole lot more than the typical backblade....Aside from getting a stiff neck from looking backward while using the backblade, is there anything else that I sholud know that would compel me to use the front mounted blade? I live in SE PA with a 500' driveway. Usually get one or two 15" snowstorms a year and a whole lotta smaller ones.
I have a little MF 220.... 26 hp at the pto....and a 5' loader bucket
Aiken Trailer and Tractor
   / Virnig Snowplow #8
I considered Virnig Snowplow for my recent purchase, but that was a little more plow suitable for my needs. I went with the FFC 1482 1400 Series hydraulic angle snow plow/dozer blade. With an approximate weight of 500 pounds and dozer blade capabilities, it was just what I was looking for to snow plow my 1000 plus foot steep driveway. The blade allows the option to swap-out the trip spring setup and replaces with a long set of eye-bolts allowing light dirt plowing/grading.
If you have not done so, checkout FFC’s website at: FFC
   / Virnig Snowplow #9
I use a power angle Diamond
   / Virnig Snowplow #10
Last year a TBN'er got a Diamond (Meyer) blade for his Kubota. It was priced less than my Curtis. I paid $1700 with shipping for my hydraulic angle 6 1/2' blade. Had to weld the brackets to fit my B2910 FEL.
I have had mine for 6 years now. It has been a great setup for clearing snow.
Blade picture
   / Virnig Snowplow #11
I also looked at the Virniq, but it is far too heavy for a compact. I own a Virniq rock bucket, which is good quality. Now I am looking at Sno-Way and Horst Welding blades which are in the 475-550# range.
   / Virnig Snowplow
I finally got a quote back from Iowafarmequipment.com on the 8' Virnig snowplow blade. It is $2,899 including hydraulic hoses and couplers. Truthfully, that's not as high as I thought it would be. But it's one serious implement. I think I will look at some of these others that have been suggested. They should be more reasonable in price and utility.
   / Virnig Snowplow
I am actually leaning towards the Curtis tractor blade or, less likely, maybe the Meyer diamond after reading the comments and researching the internet. On the Curtis website the photo shows the optional Skidsteer adapter bracket. Perhaps some of the guys who have Curtis blades could comment on this:
  • Is the optional Skidsteer adapter bracket necessary/useful for QA loaders?
  • Did you purchase through a local dealer or the internet?
Any words of wisdom would be appreciated.
   / Virnig Snowplow #15
I do not have a QA Skid Steer loader. Mine is a Quick Coupler pin type loader.
I had to modify my blade attachment when I got the Quick Coupler. What a difference. I know have 5 attachments that fit the Quick Coupler. Sure is easy to switch attachments. For the size tractor you are considering. I would not purchase it without a Skid Steer type adapter. Get the Blade with the bracket.
I purchased my blade direct from Curtis. Made arrangements to have blade delivered to my Kubota dealer. This saved the residential delivery fee. I do not believe that Curtis sells the blades direct any more.
   / Virnig Snowplow
I just checked out Kubota's website. The loader for the M8540 has a skid-steer type Quick Coupler. Hmmm. But I am actually planning on getting the tractor with a Quicke Q35 loader. Hmmm. Now I'm confused.:confused: I may have to discuss this with the dealer! Hopefully I don't show my ignorance!:eek:
   / Virnig Snowplow #17
Glowplug said:
I just checked out Kubota's website. The loader for the M8540 has a skid-steer type Quick Coupler. Hmmm. But I am actually planning on getting the tractor with a Quicke Q35 loader. MMM. Now I'm confused.:confused: I may have to discuss this with the dealer! Hopefully I don't show my ignorance!:eek:
I would hope that the loader has a Skid Steer type adapter. On their site Quicke does not show a SS adapter. But here is the states they may have one.
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A61307)
2014 Doyle Dry...
TANK MANIFOLD (A58214)
2008 Chevrolet C7500 Altec TA40 41ft. Bucket Truck (A59230)
2008 Chevrolet...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
2015 CHEVROLET 2500 HD CREW CAB FLATBED TRUCK (A60430)
2015 CHEVROLET...
