Muhammad,
I did some experimentation tonight to time the open/close cycles of the Long 4 in 1, HJ2-60" mounted on my Kubota
B2910 w/LA402 loader. It was about 35 degrees (F) outside so I let the tractor warm up for several minutes and worked all the cylinders through several cycles. Then set the rpms to 2000. Clocked the cycles several times with my wrist watch.
Results: Time to OPEN from fully closed: 3.5 sec
Time to CLOSE from fully opened: 2.5 sec
I belive these to be accurate within 0.25 seconds.
Here is another issue I discovered that may be a
SAFETY CONCERN under unusual circumstances. This has to do with having both the non-regenerative and regenerative capability available with the 4 position valve spool for the bucket. When the 4 in 1 is plumbed to OPEN (w/solenoid engaged) in the normal DUMP position, moving the FEL joystick further to the right..beyond the detent...puts the 4 in 1 cylinders into a regenerative mode.
The already OPEN bucket will immediately CLOSE under its own weight. Happens in about 2 seconds! So the scenario could look like this: Trying to open the bucket just a tiny bit further, or by accident, you move the spool into regen mode and WHAM! the bucket closes. Remember...normally to CLOSE you move the stick passed center in the OTHER DIRECTION. We all know it would be foolish to have anyone near the tractor in any circumstances while working...but, it's not too hard to envision a lack of judgement involving someone near the bucket and "body parts" caught in the squeeze of a couple hundred pounds or thereabouts. Just thought I should point that out. Clears my conscience a bit. Hope the rest of the info is useful to someone.
