Wallenstein backhoe?
/ Wallenstein backhoe? #1
NewfieDan
Eastern, NL
Kubota BX2360
I have been toying with the idea of a backhoe for my BX2360. I haven't pulled the trigger on one yet for a number of reasons, one of which is switching between implements/trailers.
I may have come across a solution. A backhoe by Wallenstein. They seem to mount to a 3pt hitch and have the hydraulics driven by the PTO.
Does anyone out there know anything about them, or have experience with them?
/ Wallenstein backhoe? #2
Wallenstein is a good BH. However, you would need to buy or build a subframe to mount it on your BX2360. Any compact or sub compact tractor that uses a BH should have it mounted to a sub frame since a BH puts a lot of stress on the tractor 3 pt. I just bought a used Woods BH750 with a sub frame and PTO pump for my 37HP tractor. The sub frame was made for another tractor so I have to modify it to bolt up to my tractor.
/ Wallenstein backhoe? #3
let me know when your ready to part with that attachment as well, I love the snowblower! :laughing:
/ Wallenstein backhoe? #4
Glad the blower is working well for you. I knew I sold it too cheap. I think I sold the 2615 too cheap also, was only on CL a couple days.
/ Wallenstein backhoe? #5
Newf Dan.... I have a Wallenstein BHwith a 3 point set up. I use it alot in the summer I have had no issues with the hoe I did break the top link bracket on the tractor off only because it was really under sized had a new one built from 3/8 stock and working great now for 3 years.
I have a branson tractor and I know of another guy with the same tractor. He has a subframe with his hoe. Issue he has is the subframe has to be removed to use the 3 point set up for another implement.
So in my case a subframe does me no good as I may change the hoe out 2 times in a day.
Rasaorbackq that is exactly my point. I don't want the addition of a subframe. But I also can see Grorge's point about the additional stress on the tractor. I already have a subframe that has to come off whe I switch from the plow/snowblower to the FEL. Another subframe may not be that bad depending on how it attaches. It would still be better than taking off the 3pt hitch to put on the backhoe.
The other question is how would it work in the soil where I live? I am in Newfoundland Canada, known locally as The Rock. When clearing land for a greenhouse earlier I had to use a hammer and chisel to get out some of the rocks. They were about the same size a steering wheel and the ground around them was packed solid. Like digging in a roadway. Or would it be better to use a bigger piece of equipment.
/ Wallenstein backhoe? #7
I would be very careful about mounting a backhoe on a three point. It is almost always the top bracket that breaks, many times along with the rear end housing, as they are not designed to withstand the multiplying of force by having a fulcrum projected out 8 or 10 feet and hundreds or thousands of pounds of force applied via a hydraulic cylinder. All of this force applied to a single top 3 point bracket will break things if you are not *really* careful. And with rocky soil, and the high shock loads that you are going to encounter, I would be surprised if you didn't break something on the tractor. Lets say that you fix the top bracket when it breaks by making a heavier duty one, then the question is what breaks next? Almost certainly it will be what the upper bracket is attached to, almost always the rear end casting.
You can lower the risk somewhat by using small, narrow buckets, but I would careful none the less.
One last thing I will mention is that a well thought out subframe is not very difficult to attach/remove. The one I used to have had the front of the frame that plugged into sockets mounted to front of the tractor and the rear had three bolts on each side. I think the most difficult part of re-attaching was backing up the tractor to the correct point to align the rear mounting bolts. The front of the frame I kept on a stack of 4x6s, so it was kept high enough to fit into the sockets. The trick was to back it up parallel to the backhoe subframe, and that was either trial and error or getting someone to give me signals. It would have been much easier to put one of those auto backup cameras on the back so I could have seen better myself.
/ Wallenstein backhoe? #8
I think you would be best off to sell your tractor and get a BX25D. You know everything is going to work right on the BX25D. The fit may not be as nice on the wallenstein.
/ Wallenstein backhoe? #9
Definitely the best solution - trade up!
I had a 3PT BH on my L185DT, BH built by Kubota too, and the top link was the weak link and we have rocks similar to you in NS.
With the integrated BH on the BX25 and on my B21 it was a night and day difference in ease of use and control.
/ Wallenstein backhoe? #10
Neffie dan..... I often have to dig out rocks that large and packed together Hardest part is to get the teeth in between . I like my BH bigtime.
I built a manual thumb for $100 because many rocks I play with are larger then the bucket.
/ Wallenstein backhoe? #11
Below is a list of the belly mount subframe that would be required to fit a Wallenstein BH to your tractor. I would suspect that the hoe you are considering already has a mount with it.
I currently have a Wally backhoe GX500 with a belly mount for B1700 that I no longer use. Not trying to make a sale here as I will likely modify or order a new belly mount frame to fit my B2650 or I am considering trading it for a Kubota hoe that would fit miy tractor. Other than busting a hydraulic hose due to it rubbing on a metal part, it has been a good hoe. The smallest hoe GX500 requires a min of about 4 gal/min of flow. My B1700 met this requirement so a PTO Pump was not required. It looks like the GX500 (5 ft depth) is no longer made but the small size in my opinion would be ideal for a BX sub compact tractor. BTW mounting the sub frame entails removing the lower lift arms of the 3pth (no big deal) attaching the hoe subframe where the lift arms were and attaching the front of the subframe to the FEL frame with a couple of pins.
BX1850 3631A450 Belly GX620
BX2200 3630A100 Belly GX620
BX2230 3630A100 Belly GX620 the 2nd col is the subframe part number
BX2350 3631A450 Belly GX620
L2250 3631A500 OEM ROPS Belly GX620/GX720
Hope this helps
/ Wallenstein backhoe? #12
I'm going to respectfully disagree at to the necessity of subframes. I ran a Woods 750 on a NH 3415, 1710 and 1920 for 16 years without subframes and without any ill effects. But, then, I never abused it, but I did work it hard at times. I am, though, highly experienced, having taught and written appropriate operating techniques. My only point is that a competent operator who understands the dynamics of the loads imposed by their operating can compensate for the lack of a 2nd rigid retention system.
2016 Chevrolet Caprice Sedan (A61569)
2016 Chevrolet...
INGERSOLL RAND G25 GENERATOR (A58216)
INGERSOLL RAND G25...
UNUSED JCT QUICK ATTACH 60" PALLET FORKS (A62131)
UNUSED JCT QUICK...
2015 DODGE DURANGO RT SUV (A59575)
2015 DODGE DURANGO...
10 Lug Wheels Full Set (A57453)
10 Lug Wheels Full...
New/Unused Landhonor Transfer Pump (A61166)
New/Unused...
