Wallenstein backhoe?
   / Wallenstein backhoe? #1
NewfieDan
Eastern, NL
Kubota BX2360
I have been toying with the idea of a backhoe for my BX2360. I haven't pulled the trigger on one yet for a number of reasons, one of which is switching between implements/trailers.
I may have come across a solution. A backhoe by Wallenstein. They seem to mount to a 3pt hitch and have the hydraulics driven by the PTO.
Does anyone out there know anything about them, or have experience with them?
   / Wallenstein backhoe? #2
Wallenstein is a good BH. However, you would need to buy or build a subframe to mount it on your BX2360. Any compact or sub compact tractor that uses a BH should have it mounted to a sub frame since a BH puts a lot of stress on the tractor 3 pt. I just bought a used Woods BH750 with a sub frame and PTO pump for my 37HP tractor. The sub frame was made for another tractor so I have to modify it to bolt up to my tractor.
   / Wallenstein backhoe? #3
let me know when your ready to part with that attachment as well, I love the snowblower! :laughing:
   / Wallenstein backhoe? #4
Glad the blower is working well for you. I knew I sold it too cheap. I think I sold the 2615 too cheap also, was only on CL a couple days.
   / Wallenstein backhoe? #5
Newf Dan.... I have a Wallenstein BHwith a 3 point set up. I use it alot in the summer I have had no issues with the hoe I did break the top link bracket on the tractor off only because it was really under sized had a new one built from 3/8 stock and working great now for 3 years.
I have a branson tractor and I know of another guy with the same tractor. He has a subframe with his hoe. Issue he has is the subframe has to be removed to use the 3 point set up for another implement.
So in my case a subframe does me no good as I may change the hoe out 2 times in a day.
Rasaorbackq that is exactly my point. I don't want the addition of a subframe. But I also can see Grorge's point about the additional stress on the tractor. I already have a subframe that has to come off whe I switch from the plow/snowblower to the FEL. Another subframe may not be that bad depending on how it attaches. It would still be better than taking off the 3pt hitch to put on the backhoe.
The other question is how would it work in the soil where I live? I am in Newfoundland Canada, known locally as The Rock. When clearing land for a greenhouse earlier I had to use a hammer and chisel to get out some of the rocks. They were about the same size a steering wheel and the ground around them was packed solid. Like digging in a roadway. Or would it be better to use a bigger piece of equipment.
   / Wallenstein backhoe? #7
I would be very careful about mounting a backhoe on a three point. It is almost always the top bracket that breaks, many times along with the rear end housing, as they are not designed to withstand the multiplying of force by having a fulcrum projected out 8 or 10 feet and hundreds or thousands of pounds of force applied via a hydraulic cylinder. All of this force applied to a single top 3 point bracket will break things if you are not *really* careful. And with rocky soil, and the high shock loads that you are going to encounter, I would be surprised if you didn't break something on the tractor. Lets say that you fix the top bracket when it breaks by making a heavier duty one, then the question is what breaks next? Almost certainly it will be what the upper bracket is attached to, almost always the rear end casting.
You can lower the risk somewhat by using small, narrow buckets, but I would careful none the less.
One last thing I will mention is that a well thought out subframe is not very difficult to attach/remove. The one I used to have had the front of the frame that plugged into sockets mounted to front of the tractor and the rear had three bolts on each side. I think the most difficult part of re-attaching was backing up the tractor to the correct point to align the rear mounting bolts. The front of the frame I kept on a stack of 4x6s, so it was kept high enough to fit into the sockets. The trick was to back it up parallel to the backhoe subframe, and that was either trial and error or getting someone to give me signals. It would have been much easier to put one of those auto backup cameras on the back so I could have seen better myself.
   / Wallenstein backhoe? #8
I think you would be best off to sell your tractor and get a BX25D. You know everything is going to work right on the BX25D. The fit may not be as nice on the wallenstein.
   / Wallenstein backhoe? #9
Definitely the best solution - trade up!
I had a 3PT BH on my L185DT, BH built by Kubota too, and the top link was the weak link and we have rocks similar to you in NS.
With the integrated BH on the BX25 and on my B21 it was a night and day difference in ease of use and control.
   / Wallenstein backhoe? #10
Neffie dan..... I often have to dig out rocks that large and packed together Hardest part is to get the teeth in between . I like my BH bigtime.
I built a manual thumb for $100 because many rocks I play with are larger then the bucket.
2008 TEXAS BRAGG 20 UTILITY TRAILER (A58214)
2008 TEXAS BRAGG...
2017 VOLVO VNM SINGLE AXLE DAY CAB (A59575)
2017 VOLVO VNM...
2022 John Deere 1023E MFWD Compact Utility Tractor with 120R Front Loader (A56438)
2022 John Deere...
John Deere 2640 2WD Tractor with 146 Front Loader (A57024)
John Deere 2640...
Unused 78" Bucket Attachment (A55272)
Unused 78" Bucket...
*Selling at Royal Auction Tampa, FL Location* Year: 2017 Make: Dodge Model: Charger Vehicle Type: (A59231)
*Selling at Royal...
