Gordon Gould
Super Member
- Joined
- Apr 1, 2007
- Messages
- 6,703
- Location
- NorthEastern, VT
- Tractor
- Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
On the oiled wire rope-- be very stingy with the oil. Oil is made to migrate over parts surfaces. Any oil gets on your clutch faces and you will not be pulling much wood. Farmi puts large notices in their manuals that the drive chain and cable should not be oiled for this reason. Another thing - you drag the cable thru the dirt. An oiled cable will pick up and hold more dirt and grit which will wear the cable quicker as it acts as an abrasive. Like most things some people use oil and some don't and every thing has trade-offs . I am not saying it is good or bad. Just be aware of the consequences of to much. I have never oiled my cable. It may seem "dry" after sitting a while but with use it slicks right up. 10-4 on the protruding wire slices - gloves come in handy.
Winching yourself in works to tension your cable. Find a slight uphill slope so you won't get rolling from the momentum and loose your tension. (EDIT: or set the parking brake so it drags a little.) Easiest is to just drag in a log or some other thing that drags hard. When I have help I hook to the lawn tractor or 4 wheeler and winch it up a good hill on the road while the grandson steers the lawn tractor/wheeler.
gg
gg
