Want to buy a used Grasshopper and need advice.
   / Want to buy a used Grasshopper and need advice. #21
Front mount rear discharge deck mower is the way to go if you need to mow a lot around hedges, trees & bushes etc.
I don't agree on the "rear" discharge on the front mount GH.
May be fine IF you live where you have a paved drive ect., but here where I live, that rear mount GH mower throws all kinds of dirt and dust right on the motor and the driver! I tried one, and like my dealer said, they need to be kept in town.
I went for the side discharge on both of my GH's and I'm happy with how they work, even under bushes ect...
SR
   / Want to buy a used Grasshopper and need advice. #22
SR
I’ve heard plenty of complaints about making wind rows and clogging the radiator up with rear discharge decks. There’s a good reason they aren’t very common.
   / Want to buy a used Grasshopper and need advice. #23
Another reason to consider the side discharge: I am fairly certain you can't use the collection system with a rear discharge deck. I don't use the collection system for grass as I like to leave the clippings. However, in the fall I put on the collection system for leaf clean up. Can't be beat for clean up. And it grinds the leaves and gives me awesome leaf mold after a year of sitting.
   / Want to buy a used Grasshopper and need advice. #24
Sure everyone has an opinion, just like...
   / Want to buy a used Grasshopper and need advice. #25
.....................If buying used, make sure you get one with the newer transmission - the G2 drive. The old one was fine (Gemini) but when they go, it's very difficult to find a replacement, and of course the Gemini hydros can only be bought used now.
Well, I was doing some online checking for Eaton Gemini 771 & 770 hydro transmission parts at a Grasshopper dealer and had no trouble finding individual parts listed & prices.
Did not try buying those since I don't need any, but they seem to be available.
Did not find complete new hydro drives available, but a bunch of used hydros are listed on the eBay from $800 OBO to $1500 each so hopefully I will never need one of those.
If the mower is used only for lawn mowing on reasonably level ground (IE no snow plowing, pulling a trailer etc.) and if oil & filters are changed according to schedule, these hydro drives should outlast the engine. I hope.
I'm looking at an excellent condition 723K H2. One owner and a good family I know. 395 hours. Any thoughts on that mower or type or drive system? I don't know if it's a G2 or whatever.
Also, it's a 23HP air cooled Koehler. Would really like a diesel or at least a liquid cooled gas engine but this would work for getting under my trees, etc and I could use my 7' rear mower for the open areas.
   / Want to buy a used Grasshopper and need advice. #27
That is exactly what I have, 723K H2 drive system. A 52" deck is good for it, anything bigger I feel would be way too under powered, sometimes it struggles with the 52" in thick grass or thicker/taller than normal grass while going up a hill. I think aot of those came with turf tires and a single tail wheel, mine did, the turfs went away for lug tread tires and the single tail got changed to a wide tail, each setup has their advantages or drawbacks, I found swapping to a wide tail was best as it was easier to load.
Other than I bought my 723 with 400 ish hours on it and I have 850. The only thing I have replaced on the engine and tractor unit is a stator assembly that went bad, a pto switch, the idler pulley and bushing for the belt drive on the pto from the clutch to the prop shaft, each pillow block bearing under the tractor (one was bad the other got replaced while doing the job), a fuel pump and one hydraulic hose. 8 years and 400+ hours.
Birdhunter1---check your PM--Private Messages-- from me.
   / Want to buy a used Grasshopper and need advice. #30
Maybe try finding a Steiner?
Forward 10,000lb Two-Post Electric Auto Lift (A55851)
Forward 10,000lb...
2017 KOMATSU PC360LC-11 EXCAVATOR (A60429)
2017 KOMATSU...
2011 DOOSAN G40 GENERATOR (A55745)
2011 DOOSAN G40...
MODEL 14C SCRAPER (A58214)
MODEL 14C SCRAPER...
2017 CAT 315F LCR EXCAVATOR (A58214)
2017 CAT 315F LCR...
UNUSED FUTURE 32"...
