Was removing, now installing PTO shaft ??s
   / Was removing, now installing PTO shaft ??s #1
lhfarm
Central Indiana
NH TC40DA
Got the shaft off a very old (at least 35 years) 5' Bush Hog brand mower. The tractor end of the shaft was set up for a 1 1/8" spline and I need a 1 3/8 quick coupler. The mower end was keyed and had a bolt through the shaft too. Purchased a King Kutter replacement shaft - I matched the length and shaft sizes at TSC. The fit is perfect, except the shear bolt size. The new shaft has a 1/2" hole and the mower is 5/16".
Should I drill out the mower shaft (not going to be easy) or try to find a matching end (small shear bolt hole)?
Should I add a slip clutch (torque limiter?) between the mower shaft and the drive line?
Any suggestions appreciated.
   / Was removing, now installing PTO shaft ??s #2
Oh, wow! A 1 3/8 to 1 1/8 adaptor would have set you back less than $10. /forums/images/graemlins/shocked.gif
</font><font color="blue" class="small">( Oh, wow! A 1 3/8 to 1 1/8 adaptor would have set you back less than $10. /forums/images/graemlins/shocked.gif )</font>
Before I got the new tractor, that was what I was using. It had a pin hole for locking onto the PTO shaft. My new tractor doesn't have the hole. So I tried to find a quick connect 1 3/8 to 1 1/8 adaptor, but no luck. So I had one welded up. Last weekend, a buddy was helping me mow and engaged the PTO with the engine at 540 RPM and snapped the 1 1/8 spline where it went into the old driveline. Scared the &&&^^ out of me. For safety, I thought I should get the correct style shaft.
   / Was removing, now installing PTO shaft ??s #4
<font color="blue"> Should I drill out the mower shaft (not going to be easy) or try to find a matching end (small shear bolt hole)?
</font>
Barry,
Do you have sufficient length to cut the end off and drill the hole size you want in the shaft? I wouldn't concern myself with a slip clutch with a 5/16" shear bolt. It should shear before damaging something else.
TK
   / Was removing, now installing PTO shaft ??s #5
I run our brush deck with an Over-Running Clutch. This is in addition to the shear bolt at the implement end of the PTO shaft. The clutch lets the deck free-wheel when the tractor stops - preventing the momentum of the blades transfering back into the tractor and continuing to push it forward.
cvt
I am using bronze bearings to reduce the 1/2" to 5/16" and that seems to be working ok. I figure the smaller size is just another safety factor.
Thanks for all the replies.
   / Was removing, now installing PTO shaft ??s #7
I would either bushing down the 1/2 holes in the yoke to 5/16 and use the 5/16 bolt, or I would take the pto yoke, turn it 90 degrees and drill a 5/16 hole thru it.. make sure it is square.. use a drill press or let the machine shop do it.. might set you back 10$ if you walk in at lunch time, cause it will take the guy less time to chuck up a mill than to make out the 'paperwork'.. etc.
soundguy
CATERPILLAR 926M WHEEL LOADER (A60429)
CATERPILLAR 926M...
KIVEL 48" PALLET FORKS 3500 LB CAP (A60430)
KIVEL 48" PALLET...
2012 FREIGHTLINER CL120 CONVERTED TANDEM AXLE GLIDER DUMP TRUCK (A59905)
2012 FREIGHTLINER...
2021 Kubota RTV-X1140 4x4 Diesel Utility Cart (A59228)
2021 Kubota...
2024 PRO FABRICATION RTM-5.2K-Y REEL TRAILER (A59905)
2024 PRO...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
