Washing a tractor
/ Washing a tractor #1
monkeybreath
Central California Foothills
Kubota 3410
I know this may sound a bit dumb, but I have a reason for asking - what care do you need to take when hosing down your tractor - or pressure washing it ? I ask because I once caused major damage to my diesel pickup when I was cleaning and de-gunking the engine - I was told that I should never have hosed or put water anywhere near the engine. If this is true, do I have to be particularly careful if I pressure wash a diesel tractor ?
/ Washing a tractor #2
Hi Monkeybreath,
I do a lot of tractor washing at the old JD store and I never have had a problem pressure washing the engine or the whole tractor off from the small ones up to the big 4 wheel drives and such. If a tractor is really gunked up on the engine or if the mechanic spills oil or something on the engine I pressure wash it off. Just don't get the starter wet.
/ Washing a tractor #3
If you send the tractor in for service or repair they pressure wash it before they send it back. Just don't do it when the engine is hot. If you spray cold water on a hot injection pump you can shrink the housing and the hot guts can bind up and destroy themselves. You don't want to spray cold water on a hot exhaust, either. You can crack a manifold. Water can get into electrical connections and cause problems but that can happen on anything. It would be a good idea to figure out where the transmission and axle vents are located and avoid spraying water directly on them, or, more precisely, up under them. Just use a little common sense. If you wash the radiator out with a pressure washer, do it from a distance so you don't flatten out the fins. I'm sure others will come up with things to watch out for. Remember, the guy working the washrack at the dealership ain't a master tech, they hire some kid, point out the rack and tell him to wash. If there was that many things to go wrong it would cost them so it must be pretty safe to let 'er rip!
/ Washing a tractor #4
I'd also caution to use a wider spray pattern and not to spray hot engines or direct the pressure at any rubber seals or your fuel cap and vent. You don't want to blast even a tiny amount of moisture into your hydraulics or fuel system.
/ Washing a tractor #5
Ron: don't wash it when the engine is hot, also i don't use a pressure washer, just the garden hose. i got my tractor when it was clean and never allowed it to get so dirty that it need pressure washing. when washing it either with hose or pressure washer be careful around electrial, also when washing and waxing your tractor, make sure u do it in an area where the neighbors can't see you! as it will just confirm that you are a wacko /forums/images/graemlins/grin.gif also expect a few shakes of the head and a few mumbelings from the boss(wife) /forums/images/graemlins/crazy.gif
/ Washing a tractor #6
Yup, keep it clean from the start and you shouldn't need to pressure wash it. But don't hit a hot engine with cold water. You can crack the block - new engine time.
<font color="blue"> also expect a few shakes of the head and a few mumbelings from the boss(wife) </font>
And that is before anyone catches you waxing it /forums/images/graemlins/grin.gif...
/ Washing a tractor #7
I recommend parking the wifes car in the yard and keeping the tractor in the garage. Cuts down on washing. /forums/images/graemlins/shocked.gif
/ Washing a tractor #8
LOL, I tried that with my wifes truck but now its my truck thats in the drive way ! I think you should never get water on a hot engine delberately. If useing a pressure washer avoid spraying directly at the grease seals especially for the FEL. If you have a model with a plastic hood avoid getting any of the grease cleaners like the orange or purple or green stuff on it.
/ Washing a tractor #9
I rarely wash my equipment with a pressure washer. If it gets really bad or I get into alot of mud I will. I like to use a long high pressure air nuzzle and after most uses with any of the equipment I spray the dirt, oil, etc. off. This keeps the equipment pretty clean.
/ Washing a tractor #10
The main thing I would do first is unhook the battery. Water makes a great conductor. Even if you let it dryout before rehooking, you never know when something will still be wet and "zap" your wiring, and you lose all your smoke.
2014 FORD F-150 (A60736)
2014 FORD F-150...
Kholer Magnum 10 Compressor (A61307)
Kholer Magnum 10...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A59823)
KNOW BEFORE YOU...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
JLG 1230ES COMPACT ELECTRIC VERTICAL MAST LIFT (A59823)
JLG 1230ES COMPACT...
2023 CATERPILLAR 304 EXCAVATOR (A62129)
2023 CATERPILLAR...
