water 4 gas anyone look in to this.
   / water 4 gas anyone look in to this. #71
I can't believe intelligent human beings have to keep wasting their time putting down ridiculous and ignorant claims like water 4 gas. That being said, I'll waste some time here as well. All that the naysayers have said here is absolutely correct. There isn't much more to add without doing a lot of chemistry math to spew numbers on something that isn't worth the time. It wouldn't matter anyway. I've seen other discussions where this has been done and the people who believe either aren't willing to hear the truth or aren't capable of understanding it.
I will add one comment for the believers to think about. If hydrogen was a magic catalyst to break long chain hydrocarbons down into shorter ones, don't you think the oil companies would have invested in this long ago. The refinement process to get crude oil to usable fuels like gasoline, diesel, or kerosene works by breaking long chain hydrocarbons into shorter ones. These processes use catalysts and very high temperature and pressure vessels (akin to the combustion chamber on your car) to progressively break the longer chains into shorter ones.
Imagine how much more profit the oil companies could make if they would only install a water 4 gas system on their stacks and create hydrogen to make gas from crude oil for nothing. Then they would make gas for free and we could drive our cars for free, all thanks to water 4 gas. he-double-L, if we used hydrogen from electrolysis at the refineries and in our cars, we could produce more energy than we get from the original crude, use that energy to produce synthetic crude and pump it back into the ground for future generations to use when they finally learn that water 4 gas won't work.
I'm betting we'll see the believers on a list of Darwin Award winners before we see the inventors with Nobel prizes. If anyone wants to run a book on that line, let me know. I want some of that action. While I don't have the lack of morals necessary to sell water 4 gas, I certainly have enough entrepreneurial spirit to bet on their failure.
If you can't tell, the very fact that we have to have this discussion really bleeps me off.
For those of you that do believe in these systems, don't get me wrong. I encourage you to go out and try them out. Spend your money so someone can tell you how to make something that won't work. Then spend more of your money building something that will not work. This is a far better economic stimulus package than congress is ever going to come up with!
For the rest of us, we're busy looking into buying stock in mason jar companies.
   / water 4 gas anyone look in to this. #72
Yep.. if it worked there would already be a guy with a nobel proze in alternative free energy with this thing installed on his car... be a way lot cheaper than a hybred car!
soundguy
   / water 4 gas anyone look in to this. #73
Wouldn't it be easier to just drill holes in your thermostat and inject frequencies into your antifreeze???
:rolleyes:
   / water 4 gas anyone look in to this. #74
:rolleyes:
Naw, all you need is a tractor engine. I hear you can get 50 mpg if you put a tractor engine in your truck. :rolleyes:
Actually I unsubscribed from that thread at about page 20.
   / water 4 gas anyone look in to this. #75
:rolleyes:
Yeah that works great. You will get between 99 and 199 mpg IMPROVEMENT. But, sadly, there is a down side. The exact frequencies used are nearly exactly the same ones as sung by the deluded rejects on American Idol. Seriously, it's not worth the extra mpg's when you have to listen to the sound of screeching fingernails singing hip-hop / rap songs at 125 db while you drive !
   / water 4 gas anyone look in to this. #76
But you have to jimmy your computer to see those gains.. ;)
soundguy
   / water 4 gas anyone look in to this. #78
The shock absorbers could be turned into generators. As the name suggests they absorb energy and disipate it as heat so instead of heat they can produce electricity. For example you could use your children bouncing on the back seat to improve your mileage.
Yes, shocks could generate substantial amounts of current on slightly bumpy roads. I bet damping could be almost totally electrical instead of hydraulic. I also bet that would be some hella expensive shocks! :D
Another source of free electricity would be solar panels on the hood, top, and trunk lid. I bet you could crack a lot of water with 500W of solar. Question is, is it more efficient to crack water and use the H2, or use it to charge hybrid batteries? Probably the batteries, although they aren't 100% efficient either.
Another source of free power is the radiator. There's lots of heat wasted that could be used for power generation.
A source of {almost} free power is the exhaust. I suppose you can get a little free power from it but getting greedy would hurt mileage.
   / water 4 gas anyone look in to this. #79
   / water 4 gas anyone look in to this. #80
Another source of free power is the radiator. There's lots of heat wasted that could be used for power generation..
Hang a thermocouple up there.. one half gets cool air, the other heat from the radiator.. .. the product is electricity.
Think about space craft.. radioactive fuel pellet producing warmth, cold of space.. = electricity..
soundguy
71059 (A49346)
71059 (A49346)
2005 International 4300 Heil Dump Truck (A50323)
2005 International...
2020 KUBOTA RTV...
2020 Kinze 3505 High Speed 6/11 Planter (A52128)
2020 Kinze 3505...
2016 Ford Explorer...
2010 Case 660 Trencher (A50322)
2010 Case 660...
