Water Hauling Trailer
   / Water Hauling Trailer #11
How come it's only $1 to load? What's the point in even charging?
The well in town has a hose on a meter and it costs 25 cents for 50 gallons. So it would be 2.50 to fill my 500 gallon tank. I believe the RR runs the well. I imagine all those quarters raise enough money to keep it operational (hoses, electric, etc.). I'm sure they could double it and not lose any business, but it's sort of a RR town, so I think it's their way of providing. That's my 2 cents on the subject. :thumbsup:
   / Water Hauling Trailer #12
I have 2 good wells but they wont keep up with livestock swimming pool and garden this year its been way to dry. I only got 2 cuttings off my hay and mowed yard once since end of July everyone around here is hauling water.
Fyi I don't know the rule on how big of tank can haul without cdl with tanker endorsement. I doubt they would mess with home owner
I am curious why you haul water and just don't dig a well? I am sure there is a good reason but it seems like it would pay for itself quickly.
As for towing water I would want the load as low as possible and a deck over is not going to do that very good. As far as saving weight, what are you talking with a new trailer? Maybe 300#, not worth the cost. Save your money and get yourself a F-350 SRW 4x4 truck and you can haul anything you want. Skip the 3/4 ton, they are not much more truck than some of the new 1/2 tons.
Chris
All of our neighbors have wells and the water is so hard and full of iron that they have to spend about $10k on softening and filtration equipment and it only lasts about 10 years. Also washing machines and dishwashers in the area last about 5 years off of the well water, even with the treatment. Plus it tastes horrid to drink so we would be buying the blue 5 gallon jugs any way. The towns both feed off of a huge deep local lake that has amazing water that is also very good to drink. So when we added all the different factors up it was cheaper to put in the cistern and haul/deliver.
Would love to buy the 3/4 or 1 ton right away but the wife also needs a new car since we had a baby this year. Can't justify 2 vehicle purchases and the tractor in the same year, not to mention we just finished building our house. (at the same time I just saw a 2 year old GMC 3/4 Dmax crew with 27000 km for about $20000 less then new Hmmmm?)
   / Water Hauling Trailer #14
Tanker endorsement isn't a concern until you need a CDL.
Simply put if it doesn't need a CDL then it can't require a tanker endorsement.
In Alberta the destinction for the CDL liscense (Class 1) is if the trailer has air brakes. So that isn't an issue for me. Also I am not anywhere near the weight that I see some guys haul behind their 1 tons. Saw a guy with 17 large round hay bales on his tri axle gooseneck.
   / Water Hauling Trailer #16
Id build a purpose built trailer. No deck, just axles and frame under the tank.
Find a neighbor/friend that also can use it and split the cost with him.
when looking at used trailers to transform into a platform to put your tank on.
remember
5 bolt hubs = 3500lb
6 bolt hubs 5K-6K
8 bolt hubs 7-8K
   / Water Hauling Trailer #18
Just remember, water weighs 8.3 lbs/gallon. So 100 gallons = 830 lbs, and 1,000 gallons = 8300 lbs. Add the weight of the trailer etc and it adds up quickly.
I would suggest getting a 500 gallon tank and filling all the way to the top rather than getting a 1,000 gallon tank and trying to fill it 1/2 or 3/4 full. The reason being is because as you travel the water will slosh around and can push you around in a light duty truck.
   / Water Hauling Trailer #19
When my fil was out of work he went to get his cdl. He said the liquid trucks were the worse with the movement of the material inside. the baffle helped but not much.
   / Water Hauling Trailer #20
Back in the 70's I drove a gasoline tanker for a summer and one time they sent me out with a tanker with no baffles. I started to go through an intersection, then slammed on the brakes when I saw someone coming who didn't appear to be stopping. The truck stopped for a couple seconds and I had lifted my foot off the brake. All of a sudden I went lunging into and through the intersection from the load shifting back forward. Fortunately that car stopped. I went straight back to the terminal and told them what they could do with that trailer.
24008 (A53422)
24008 (A53422)
FAKE (A52472)
FAKE (A52472)
PENDING SELLER CONFIRMATIONS (A56138)
PENDING SELLER...
2006 BMW 325i Sedan (A55853)
2006 BMW 325i...
MURRAY PUSH MOWER (A55745)
MURRAY PUSH MOWER...
Cushman Cart (A55853)
