Water heater location
   / Water heater location #11
Don,
One advantage in FL to having the water heater in the loft will be cheaper hot water. if the water is 135 and the loft is too.....well I think you get the idea /forums/images/graemlins/smile.gif of course as others have said a good drain pan is essiental.
Ben
   / Water heater location #12
I saw lots of water heaters in attics when I was a real estate inspector.
Get the largest pan you can to put under it, center it over a load bearing wall (50 gallons water @ 8# per. gal=400 pounds + weight of the water heater itself.
Plumb the drain line AND the temperature and pressure relief valve to the outside of the house and down to less than 6" from the ground. Any higher would be a safety hazard if the T & P valve opened.
Be sure the roof has adequate ventilation to account for the air flow it will need if it is a gas water heater.
Put an insulation blanket on it! That is the most cost effective energy saving device on the market.
Insulate the hot water pipes. Turning a faucet on 10 minutes after it was last used you will still have hot water immediately.
If the height is a problem you can buy a "low-boy" model that is shorter and larger in diameter.
Water heaters are like tractors, I have never seen anyone who regretted buying bigger but I have seen people who regretted buying smaller. Go with the 50 gallon. Even if you don't feel like you need it when you have company and the wife is washing clothes you will be glad you went bigger.
One last alternative: Consider moving it outside to it's own enclosure. When we bought this house the water heater was in the laundry room, great in Winter but brutal in Summer. I added an "outhouse" looking structure outside and moved it there. I still need to paint a half-moon on the door to make it look authentic.
Bill Tolle
   / Water heater location #13
South Florida? Paint it flat black and stick it outside on the south side of the house. /forums/images/graemlins/cool.gif
btolle, funny you should mention the outdoor structure for the water heater. That was my backup plan until I noticed how much space I have in the eaves. My kids (next door) have solar panels, and their very large storge/booster tank is in a lean-to at the back of their house.
Snowridge. you're not far off the mark. We already have solar panels to heat our pool at our present house, and were all prepared to install solar domestic water heating as well, at the new house. But, you're also correct that the panels need to face South, and we're going to have limited roof area facing South -- basically a porch roof. It's more important to me to use that for pool heating, because a pool heater is REALLY expensive compared to domestic water heating. And, yes, we need to heat the pool water in the Fall and Spring. My better half won't get in the water unless it's around 87 degrees. We don't use the pool at all in the deep Winter months when the pool water gets down below 70... The main roof of the house has an East/West orientation, with the back of the house, the West side, being shaded by a hammock of old growth live oak trees. We chose that location because the trees will frame the house like a picture, but there will be little sun on that roof. We don't want the solar panels on the front roof because they're not real pretty, and they're not as effective facing East, anyway.
I though about building a frame and sitting the solar panels on the ground facing South, and landscaping the back of them, but the trouble and expense soon straightened me out -- there comes a time in every clever idea when one has to say, "Enough is enough -- the cost of this can never be justified over a simple gas, tank-style water heater."
2020 MACK P164T (A58214)
2020 MACK P164T...
5' MOWER (A52706)
5' MOWER (A52706)
New/Unused 72inch Quick Attach Vibratory Roller (A57454)
New/Unused 72inch...
Craftsman 42 Inch Riding Mower (A57453)
Craftsman 42 Inch...
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
Sedan (A59231)
Sedan (A59231)
