Water Well 101......A few questions from a water well newbie
   / Water Well 101......A few questions from a water well newbie #31
I think what he is referring to is a variable frequency drive pump. Not three phase. It cycles up and down according to demand.
No, they are 3 phase VFD capable pumps. The controller makes 3 phase out of single phase and uses the VFD to vary the pump RPM to keep a constant pressure on the output of the pump.
Here is the Grundfoss site for their single to 3 phase controller line: Grundfos CU331SP Variable Frequency Drive | Grundfos
Aaron Z
   / Water Well 101......A few questions from a water well newbie #32
I believe in the largest pressure tank you can reasonably install.
My well is a 150' deep the static water level varies from overflowing to 20' down in the casing.
The pump is a 1 1/2 hp, 15 gpm with a 100' lift, feeding a 60 gallon bladder tank, pressure switch is set at 40-60#.
The larger the tank the less the pump will cycle, which is easier on the pump.
I wouldn't be adverse to using a pair of pressure tanks to increase the run times, it would also increase the drawdown
volume available with power outages.
One feature of my pressure switch which can be aggravating is that it has a low pressure cutout,
if the system pressure drops to below 15 psi the switch drops out and will not restart the pump untill you manually over ride the
low pressure cut out. The idea is to shut the pump down in the event the main line breaks or the well gets emptied to protect the pump
and house. The problem is when you use enough water with a power outage you have to go down to the tank and over ride it to have water.
   / Water Well 101......A few questions from a water well newbie #33
I am quite certain that you do have plenty of pressure if you have your pressure switch set correctly.
The problem with a small (16 gal.?) tank though, is pump cycling.
Your pump may be cycling on, when you draw only a gallon or two of water.
Pump cycling = pump wear.
A larger tank requires fewer pump cycles between water draws.
My system is going on 24 years on the same pump and so far so good.
I did however need to change the steel/bladder tank as humidity/water caused the bladder to leak due to rust abrasion.
A fiberglass (bladder) tank cured that.
Pressure switch contacts do need polishing from time to time as the tend to get pitted, that or change it.
(I keep a spare on hand)
One point I can't emphasise enough is to have all the plumbing steel and iron free, use brass or plastics if U want to avoid troubles.
   / Water Well 101......A few questions from a water well newbie #34
We have a 8000+ wattage portable electric start generator specifically to run the well pump, refrigerator, and freezer, when ever the power goes out.
All I have to do is roll it to the back deck, plug it in, start it, and go inside to flip the switch in the transfer switch panel box.
And also the plus is, having some lights, TV, internet, and microwave...
KC
LOL, we think alike!
I just upgraded to 9000 unit so that I can also use a few ceramic heaters. (hate hauling wood).
My setup is permanently wired via a switch box and I keep the genny battery on an intelligent charger.
I hate pulling that cord to start the genny, besides I suffer from COPD.
Power outages are not a problem but merely an inconvenience for us.
   / Water Well 101......A few questions from a water well newbie #35
as mentioned go with the largest tank you can get in your crawlspace and save your pump from working so hard..
here is a link to the wel-trol website, near the bottom is a PDF what shows all the tanks they have and their sizes..
Well-X-Trol(R) | Amtrol
We currently have a 20 gal tank and im going with a 34 or 44 gallong tank when ours goes out.. Both would fit in my crawlspace
brian
   / Water Well 101......A few questions from a water well newbie #36
You also do not want to go over 80 psi in your house. Most residential plumbing fixtures are only designed to handle 80 psi. Most municipal water districts require pressure regulators if the supply is over 80. Municipal water lines can be over 100 psi.
   / Water Well 101......A few questions from a water well newbie #37
We notice the occasional surge when the pump kicks in, but not enough to be a bother. I am not sure how many gallons my pressure tank is but it is about 5 feet tall and a good 2.5 feet diameter.
I have a well pump and a cistern with a pump in it in addition to the pressure tank. The cistern pump is what feeds the pressure tank. The well feeds the cistern. If I ever have a problem with either of the cistern or well pump and I have a well guy out, I will look into getting rid of the cistern unless I have a low flow output well. No one else around me has a cistern.
   / Water Well 101......A few questions from a water well newbie #39
A single person with a very small cold water tank certainly can have a pump last for many (24+) years.
Not very likely though,...... for a family of 4 or 5.
   / Water Well 101......A few questions from a water well newbie #40
My pump and large tank is over 25 years old and for many years it was a family of 7, including filling a 24 ft above ground pool
a couple of times a year.
Sure hope I haven't jinxed myself now.
Как зайти с телефона на кракен. kra39ac.cc  | Kraken зайти на площадку? как пополнить кошелёк? Правила диспута
Как зайти с...
2014 DOONAN (CHAPARRAL) 502BBNHTTBZF 50FT CONESTOGA XP SPREAD AXLE FLATBED (A52141)
2014 DOONAN...
2002 John Deere 110 Backhoe (RUNS) (A50774)
2002 John Deere...
2006 MACK CV (GRANITE) BOB TAIL KILL TRUCK (A52472)
2006 MACK CV...
2015 Chevrolet Silverado 2500HD (A52748)
2015 Chevrolet...
