not2old
Veteran Member
- Joined
- Oct 16, 2010
- Messages
- 1,271
- Location
- Scotch Creek, British Columbia
- Tractor
- 2010 Massey GC2610TLB
I don't remember what the problem turned out to be, but I was incapacitated at the time due to an interaction between my motorcycle and a deer so I called the local electrician/plumber/well guy.
I had him remove the fancy controller with a small pressure tank and install an old fashioned pressure switch with 80 gallon tank. That was in 2003. The switch burned out about a year later and then again in another year. I replaced the common cheap switch with a heavier unit that cost about $150.00, that features replaceable contacts. I had to replace the tank last year and I have had to do nothing since and am able to repair this simple system myself. No waiting for someone to show up and no $100.00 per hour or more labour charge. I have the pressure set for 65-85 and have regulated the house to 60psi. No pressure changes to any taps except my yard hydrants which are connected to full pressure, which makes the boss very happy. If I had too much money, I'd add another tank with a check valve to prevent having to wait to hook up the generator if the power goes out while the hydrants are in use.
