Welcome to my Nightmare!!!!
   / Welcome to my Nightmare!!!! #121
Eddie, I just picked up on this thread asnd some things are probably to late but I'll offer what I can. I used to do this sort of thing.
Parts, sounds like you are set but there are a ton of places on the net that sell kits. last time we did my BIL's jd350 the kit I found was less than half of deere. About $100 a hole, complete kit. But the more holes and bigger you go the more the cost. Shipped to my door and no tax.
Freezing the sleeves. Not needed. sort of a wives tale. You just need to clean up the lands, lube the o-rings and tap them straight in. Some folks like to install with the pistons loaded. Not me.
Rod bolts a good idea. When you install the pistons, used plenty of lubriplate, rings and all. Put some rubber hose on the rod bolts to protect the crank and to help guide then on. Libraplate everything.
Loading up the oil filter. In a perfect world, yes. Doesn't do much good if you used the proper amount of assemble grease. The oil will pick up in seconds. I would not load the filter with diesel.
Head bolts, sounds like you have what you need. otherwise start in the middle and work out.
Sleeves, well late again, what you made works nice. Ususlly once you get them up an inch or so they will clear the lands and slide right out.
Cylinder head. I would have said to check it out first. You can pull the valves with a deep socket and a couple hammer blows. Then inspect the valve seats for pits. If decent then just run them through a wire wheel to clean and reinstall. A valve spring compressor is only about $25. But on a low revving diesel sometimes you can compress them by hand (leaning heavy on it) with a helper installing the keepers.
To bad I'm not closer to help. Still love to do this even though I run an IT shop for an oil company now. But after about 10 hours on a fresh rebuild of my BIL's jd350, he burned it up again. Brush ripped off the oil pressure gauge line. Put a loose fitting bolt in the galley(not 1/8" pipe!!!) and ran it without checking for leaks. 90 minutes later she stopped. It's locked up now. It was running perfectly to. Oh well.
Good Luck on the completion. Sorry for the spelling, in a hurry.....
   / Welcome to my Nightmare!!!! #122
   / Welcome to my Nightmare!!!! #123
but hope to get the rebuild kit tomorrow
Hi Eddie:
Any pictures of the kit?
A lot of us have never seen these components laid out on a sheet.
   / Welcome to my Nightmare!!!! #124
Hi Eddie:
Rob,
Thanks for the offer of help and your advice. I did add an oil preasure guage to the engine to see if my problems were too much oil preasure. Nope, 60 lbs at idle.
Dave,
I'll do that in the morning. The kit is very complete, but I added some things and waiting until it all came in to order the connecting rod bolts. Then yesterday I went to put the wrist pin bushings in the freezer so they'd go in easier.
After going through everything, I learned that they are not part of the kit and that they are not always changed. Anybody heard of this before? Mine look warn on the sides and there are a few odd marks on them, but overall, I'd guees I could have kept them.
Cost is $6.50 each.
They are coming from Atlanta and should be here Saturday, but Saturday delivery has to be before noon, or I have to wait until Monday.
In the meantime, I'm putting new carbide cutting teeth on my auger!!! /forums/images/graemlins/grin.gif
Eddie
Rob,
Dave,
Cost is $6.50 each.
Eddie
   / Welcome to my Nightmare!!!! #127
Eddie, the wrist pin bushing rarely wear out, but it's still good to check them. They are usually inexpensive, and having them installed, then honed to size is not much $$$$.
   / Welcome to my Nightmare!!!! #128
IH,
Thanks, I really appreciate your help and assistance. I know so little about what I'm doing here that my biggest fear is that I'll get it all back together, fire it up, run it long enough to think it's all good. Then in the middle my jungle, it will blow up and I'll have to deal with it half a mile from the shop in a tangle of trees, brush and vines!!!
With yours and the other guys advice, I'm feeling more confident in this project. I'm also hoping that my caution and frear of screwing up will ensure I don't do anything drastically wrong. /forums/images/graemlins/shocked.gif
Eddie
IH,
Eddie
UNUSED RAYTREE RMSG29 - 29" STUMP GRINDER (A54757)
UNUSED RAYTREE...
2018  FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
2835 (A54757)
2835 (A54757)
2025 JMR 36in Mini Skid Steer Bucket (A53421)
2025 JMR 36in Mini...
